Yc86 Clutched January 19, 2008 Share January 19, 2008 Any users of puck style clutch here? I just changed to a 4puck sprung clutch, and still getting used to it. Noticed that when moving off, there's a judder everytime which i think it's coming from the engine. 1. Is it because of the sudden engagement of the clutch that the engine mounts are absorbing the vibration? That would mean a shorter life for my mounts right? (the mounts are hardened already) 2. There's this burning smell too everytime i try to make the moving off smoother, or trying to park the car. Is this part of the running in of the clutch? or am i really burning the pads away... 3. How long will the pads last? and is there anyway to convert the pads to be changeable? coz mine currently have to change the whole disc. ↡ Advertisement Link to post Share on other sites More sharing options...
Dynaway 1st Gear January 19, 2008 Share January 19, 2008 (edited) ur fly wheel... is worn one side, uneven wear... same as mine... also jutter.... after awhile like 1-2 weeks, it should go away or minimise the jutter effect. did u see ur cond of the old clutch plate n clutch cover??? mine was worn one side tapered wear.... stiffen susp, stiffen engine mount will more likely to cause the CV joint wear faster due to the hard shock... u using this type of clutch, not advisable to keep doing half-clutch for low control... this type of clutch would more suited to be "thrown" instead of doing half-clutch.. u can burnt the pads if u keep doing half control... Edited January 19, 2008 by Dynaway Link to post Share on other sites More sharing options...
N00b 4th Gear January 19, 2008 Share January 19, 2008 can share wats a puck style clutch?? Link to post Share on other sites More sharing options...
Yc86 Clutched January 19, 2008 Author Share January 19, 2008 Uneven wear? or could also be the clutch cover warped/not tighten correctly? (supposed to tignten opp bolt alternately?) mech says my old cutch still can be used actually.. doesn't look unevenly worn or warped. last time with the full face clutch was fine, no juddering at all.. Hopefully will go away though, quite irritating n noisy.. Trying not to half clutch and let the pedal go asap when moving off.. not expecting the pads to last very long coz i see like quite thin i think the material is like ceramic kind? Link to post Share on other sites More sharing options...
Yc86 Clutched January 19, 2008 Author Share January 19, 2008 something like this... not the one i'm using though bt similar 4 puck or 4 pads. usually comes in 3,4 or 6 The lesser number of pads, the higher the pressure on the cover = more grip but also more harsh and not v.drivable. [inline "Copy of puck.bmp"] Copy of puck.bmp Link to post Share on other sites More sharing options...
Dynaway 1st Gear January 19, 2008 Share January 19, 2008 dun think the tightening procedures will affect tat much. more like uneven wear... the old clutch plate would have already seat-in to the wear....so wont jutter... tat is why some ppl will re-surface the flywheel when they install a new clutch... ↡ Advertisement Link to post Share on other sites More sharing options...
Marbella DashCam Users
Clutch
Clutch
Clutch for Volvo V40 T4 2013 Price?
THINKWARE / INAVI Users, Come In
For Android Users, Google Play Celebrates 25 Billion Downloa
