Dlar2 Neutral Newbie March 24, 2008 Share March 24, 2008 (edited) Really need advise or help from bros here. If you are a dentist, then all the more better. My bottom molar (the last tooth at the rear) is painful. The tooth had a crown but do not hae root canal done. I am given 3 choices by my dentist but I need some help here. 1. Extract the tooth and forget about it. 2. Extract the tooth and 4 months later do implant (cost S$4K of which S$1.5k can claim CPF and the balance in cash) 3. Take out the existing crown, do root canal then do a new crown.(Root canal S$0.8k and Crown S$0.5k) Help!! The pain is killing me. I got till tomorrow morning to consider, I think it is where my endurance end. Edited March 24, 2008 by Dlar2 ↡ Advertisement Link to post Share on other sites More sharing options...
Jeffang Neutral Newbie March 24, 2008 Share March 24, 2008 how come last time u did the crown never do root canal?? i did my crown on my last bottom 2 and of cos with root canal... you better go do 3! cause we need those 2 to eat all our food... Link to post Share on other sites More sharing options...
Tatsit Neutral Newbie March 24, 2008 Share March 24, 2008 simply extract.. nobody will notice or be able to c ur molar tooth.. I had 1 of my molar remove oso.. Eating or chewing is still doing great 4 me.. Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 Last time the root was healthy and no need to do, so just do crown. And also that time no $$$$ Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 The doc told me that I may not even miss the tooth if I were to extract it out. Link to post Share on other sites More sharing options...
Tatsit Neutral Newbie March 24, 2008 Share March 24, 2008 yah.. precisely.. But u might need a small operation to extract it as molar tooth has strong roots.. So find those clinic can deduct FULLY from ur CPF medisave... BTW the operation not painful at all... Link to post Share on other sites More sharing options...
Ultramega 1st Gear March 24, 2008 Share March 24, 2008 i think if you take option 2 or 3, also need to do option 1 (extract tooth) as a first step right? so why don't you do option 1 1st, wait a couple of weeks and see if you can live with it. if can then do nothing. if cannot then consider option 2 or 3. Link to post Share on other sites More sharing options...
Brock 1st Gear March 24, 2008 Share March 24, 2008 I removed my upper leftmost molar as well. Cheapest option. So far eating is not a problem for me. I just have to make sure I take extra care to brush more regularly. Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 If do option 3, cannot do option 1. Take out tooth already, where got root left to do canal?? Pls read carefully. You guys are giving me advise, please don't kill me!! Link to post Share on other sites More sharing options...
Leslielai 1st Gear March 24, 2008 Share March 24, 2008 Really need advise or help from bros here. If you are a dentist, then all the more better. My bottom molar (the last tooth at the rear) is painful. The tooth had a crown but do not hae root canal done. I am given 3 choices by my dentist but I need some help here. 1. Extract the tooth and forget about it. 2. Extract the tooth and 4 months later do implant (cost S$4K of which S$1.5k can claim CPF and the balance in cash) 3. Take out the existing crown, do root canal then do a new crown.(Root canal S$0.8k and Crown S$0.5k) Help!! The pain is killing me. I got till tomorrow morning to consider, I think it is where my endurance end. Hi, I would strongly suggest a removal and followed by an implant. All in all it will cost you about 4k but its the best solution to your problem. For a root canal treatment, its time-consuming and the crown will not last forever. The post-crown care is very important and its not uncommon for people to have their crowns dislodged when eating sticky/hard food. There is also a chance that decay can still set in from the crown margin and your remaining tooth structure. Pretty much like what you are experiencing now. I believe your crown was placed in because of a hairline crack? Actually an normal person only utilises the first molar, so you can actually live without your problematic tooth. Link to post Share on other sites More sharing options...
Comfy 1st Gear March 24, 2008 Share March 24, 2008 extract it and forget it... u don't need it anyway... ur gf or wifey or outside wife or lover will not reach that far in la.. extract is also cheaper if i not wrong... Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 You sound professional. You are a doctor? I appreciate your comments. Thanks. Link to post Share on other sites More sharing options...
Qpik Supercharged March 24, 2008 Share March 24, 2008 hullo, can share where you get quote for yr implant and what system are they using? plse pm if not convenient to announce here. tks Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 I gotthe quote from my family dentist, I just visited him 2hrs ago. You mean there are different system? Tell me about it. Link to post Share on other sites More sharing options...
Qpik Supercharged March 24, 2008 Share March 24, 2008 (edited) bro, check out the link. this is the system that i got quotation for. http://www.gpadental.com/services/implant.htm my dentists at AH didn't tell me what system they will be using but i understand they got more than 1 system. the only problem holding me back is going under the laser btw, i was given same options as u after the hairline cracked to the root. my dentist recommended extraction as the 3d x-ray showed bad result and he said that doing root canal is no gtd that it won't split. during extraction, the tooth split into two. luckily took his advice and saved more than 1k. Edited March 24, 2008 by Qpik Link to post Share on other sites More sharing options...
Leslielai 1st Gear March 24, 2008 Share March 24, 2008 No problem bro Just happened to be involved with dentistry in a small way.. I believe your dentist has explained to you the pros and cons. Its up to you now to make a decision. Link to post Share on other sites More sharing options...
Freestylers09 5th Gear March 24, 2008 Share March 24, 2008 go pluck out ...save all the trouble....behind never mind one..nobody see also Link to post Share on other sites More sharing options...
Dlar2 Neutral Newbie March 24, 2008 Author Share March 24, 2008 Can tell me how much did they quote you for implant? ↡ Advertisement Link to post Share on other sites More sharing options...
