Bond Neutral Newbie June 16, 2003 Share June 16, 2003 Hello bros, can anyone tell me the diff of DOT 3,4, 5.1??? Guess 5.1 is the best right?? What about brands, which is best?? (I abit kiasu lah) Thks many many...... ↡ Advertisement Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 16, 2003 Share June 16, 2003 before you even go to anything, make sure that you vehicle can take 4 and 5.1. check your brake fluid cover, it will tell you which DOT to use Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie June 16, 2003 Share June 16, 2003 Well DOT 5.1 has the highest ratings and if you car can take DOT 4 then go for 5.1. However if the brake fluid cover states DOT 3 only I'd suggest you stick to DOT 3 as the higher spec ones may be bad for the brake system seals ↡ Advertisement Link to post Share on other sites More sharing options...
Best Char Kway Teow in Singapore
China Car Design is the best?
All the best to parents of PSLE candidates
Which airline is the best?
