Freshmaker Neutral Newbie June 19, 2008 Share June 19, 2008 anybody know whats the reason for this? i changed my clutch and flywheel to an aftermarket one.. the idling at times when im slowing down to a halt, flatuates up and down... then my defi oil pressure goes to 0, and my car stalls. what is wrong? ↡ Advertisement Link to post Share on other sites More sharing options...
Singer Neutral Newbie June 19, 2008 Share June 19, 2008 dun u think its better to return to the workshop that fixed those stuff as it might involve more complicated matters .... hopefully not Link to post Share on other sites More sharing options...
Starsaaa Neutral Newbie June 19, 2008 Share June 19, 2008 Yeah bro go back to them and find out y?? Ask them to have an explanation, if don have ask for a refund and install back the original ones, sometimes original are better than aftermarket ones.. Link to post Share on other sites More sharing options...
Thug Clutched June 19, 2008 Share June 19, 2008 Is it a old car? May I know wad car? Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie June 19, 2008 Author Share June 19, 2008 1 yr plus car.. toyota mr-s.. thanks, will go back and have them checked it out... Link to post Share on other sites More sharing options...
Thug Clutched June 19, 2008 Share June 19, 2008 Wad did u do to ur car b4 the clutch and flywheel? Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie June 19, 2008 Author Share June 19, 2008 intake, exhaust, header, tune with fcon vpro... Link to post Share on other sites More sharing options...
Flipflop 1st Gear June 19, 2008 Share June 19, 2008 good reason to change car ! Link to post Share on other sites More sharing options...
Route88 2nd Gear June 19, 2008 Share June 19, 2008 Lighter flywheel tends to have tis problem.Issit for you car? Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie June 19, 2008 Author Share June 19, 2008 yep i think so.. anyway thats what the mec told me as well... say lighten flywheel will have this problem and ask me arrange a date where he can fully check my car why my oil press falls so low.. but whats the reason behind it? why lighten flywheel will cause this to happen? Link to post Share on other sites More sharing options...
Route88 2nd Gear June 19, 2008 Share June 19, 2008 Its all got to do with mass,rotation,inertia.Your stock flywheel has been calculated ideal for your engine.Unless an aftermarket flywheel has been tested for your car,then others deem to be a failure. Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie June 19, 2008 Author Share June 19, 2008 so it's is normal and there's practically nothing i can do to retify it? Link to post Share on other sites More sharing options...
Route88 2nd Gear June 19, 2008 Share June 19, 2008 Ask your mechanic,maybe need tuning ? Or forever play ur clutch and accelerator so tat engine wont die when doing pickup. Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie June 19, 2008 Author Share June 19, 2008 ok thanks will send my car in next week for checks.. anyway it is not when picking up but during slowing down... for example when im approaching a red light, i rev and drop gear from 4th to 3rd, then upon slowing down i will shift to neutral when the speed is very slow... or sometimes when approaching red light then suddenly green light but car speed very slow, so i clutch in and shift to 2nd, the oil press will fall very low, and at times, hit 0 and engine stalls. this happens only 4 times altogether only... i got the clutch for 4 months plus only..... Link to post Share on other sites More sharing options...
Route88 2nd Gear June 19, 2008 Share June 19, 2008 Ok,let the expect handle it Link to post Share on other sites More sharing options...
Thug Clutched June 20, 2008 Share June 20, 2008 ideally...skim ur stock flywheel to lighten it instead of getting a aftermarket one. but must get expert coz need to balNCE Link to post Share on other sites More sharing options...
Eavr4 Neutral Newbie June 20, 2008 Share June 20, 2008 There is many possibilities to your problem hence more info is needed Basically I dun think its the performance clutch and flywheel giving you the problem. 1) Check your oil pressure 2) Check your fuel pressure 3) If you have a Boost or Vacuum guage, check those too, somewhere maybe leaking Check ALL vacuum hoses, ensure all are plugged in properly. If all the above checks out, then proceed with a) Check your spark plugs (No. 1 plug is usually the most worned out so checking that should be a good guage. b) If you have a BOV installed (Turbo car), check if there is any hissing sound during idling c) Is there any engine check light on? Cos' AirFlow and O2 sensor errors should trigger that (cause engine rev to be erratic). Oh, most cars no longer use plug cables, but if urs still do, have them checked. EA Link to post Share on other sites More sharing options...
Miketow Neutral Newbie June 20, 2008 Share June 20, 2008 Hiyah - Change back to stock settle lor. ↡ Advertisement Link to post Share on other sites More sharing options...
A dying trade that needs rejuvenation
Writ of possession of HDB flat issued against dying man
Signs of battery dying?
Boss jailed for dumping dying worker by roadside
S'pore woman marries dying husband
Are you afraid of dying?
Afraid of dying alone
Regrets of the Dying
