Chisiang 2nd Gear July 1, 2008 Share July 1, 2008 The introduction of Nikon's new D700 may been one of the worst kept secrets in an industry with more leaks than the Titanic, but it was still something of a surprise coming so hot on the heels of the D3 and D300. Essentially a D3 shrunk down and squeezed into a body roughly the same size as a D300, the D700 is Nikon's first 'compact' professional SLR, and seems designed to go head-to-head with whatever Canon has up its inscrutable sleeve to replace the EOS 5D. The imaging side of the D700 is pretty much the same as the D3; it shares the acclaimed 12.1MP full frame ('FX') sensor and has the same processing engine, so we would presume output to be almost identical. The main differences (aside from being considerably smaller) are physical; there's a different shutter (good for 150,000 exposures rather than 300,000 on the D3), different viewfinder prism (with 95% coverage) and a slower burst rate. You also lose the rear LCD info panel (there's no room for it) and one of the D3's two CF card slots, but you do get a couple of extra features to soften the blow slightly; most notably a self-cleaning sensor and a built-in flash. We'll look a little more in-depth at the differences between the D3 and D700 in a moment. The D700 joins the D3 as a fully-fledged 'professional' model; it has the same tank-like build quality (though we're sure the pop-up flash will cause a few raised eyebrows), and gets you the full pro service from Nikon. And the pricing (around $2999) reflects this; anyone hoping for an 'affordable' semi-pro full frame Nikon SLR will have to wait until the cost of producing such large sensors falls considerably. Nikon D700 Key Features 12.1 megapixel full-frame sensor (8.45 ↡ Advertisement Link to post Share on other sites More sharing options...
Rncw 5th Gear July 1, 2008 Share July 1, 2008 i'll probably go for this as i skipped the D3/D300. Link to post Share on other sites More sharing options...
Sk_2 Neutral Newbie July 1, 2008 Share July 1, 2008 BBB Link to post Share on other sites More sharing options...
Chisiang 2nd Gear July 1, 2008 Author Share July 1, 2008 lol! That's a term I never hear for a long time le. BBB! Link to post Share on other sites More sharing options...
Comfy 1st Gear July 1, 2008 Share July 1, 2008 buy for me can? Link to post Share on other sites More sharing options...
Shull Turbocharged July 1, 2008 Share July 1, 2008 now let's see how will the 5D mkII(or whatever Canon decided to call it) will do to compete with this.. been waiting for the next '5D' to replace my 20D..wanted a full frame badly.. Link to post Share on other sites More sharing options...
Megaweb Clutched July 1, 2008 Share July 1, 2008 your current cam cannot take great photos meh ? Link to post Share on other sites More sharing options...
Rncw 5th Gear July 1, 2008 Share July 1, 2008 can, but want to try full frame cam for WA mah i'm fine with DX also, cos some of my lenses are DX format. Link to post Share on other sites More sharing options...
Megaweb Clutched July 1, 2008 Share July 1, 2008 what a good excuse to buy Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 1, 2008 Share July 1, 2008 lol! That's a term I never hear for a long time le. BBB! sorry, what is BBB? anyway, this should cause the D300 price to go down some more.. so those who don't need the latest, better hang on for awhile FX is good but not the be all and end all.. otherwise the DX lenses will be damn wasted. can still use but wun make full use of the FX sensor Link to post Share on other sites More sharing options...
Madsumm 1st Gear July 1, 2008 Share July 1, 2008 $2999 is in USD. I will check it out in Japan. What I've heard is that its exactly the same as D300, except the FX. The Viewfinder is unique too, unfortunately, at 95%. All accessories of D300 can be use back like MB-D10 and the batt is EN-EL3e. FYI, SB900 Flashgun is also launched. If you go for D700, you better get the SB900. This flashgun is specially made for FX and can reach 200mm. (SB800 only 105mm) One thing I don't understand. Why do they build a built in flash in D700? This is the only Fullframe cam that has a built in pop-up flash as far as I know. Rgds Link to post Share on other sites More sharing options...
Huggable Clutched July 1, 2008 Share July 1, 2008 BBB = Buy Buy Buy (virus) Link to post Share on other sites More sharing options...
Huggable Clutched July 1, 2008 Share July 1, 2008 Can live with the 95% viewfinder. The pop-up flash is a little weak too, but should be enough for fill-in. ISO25,600 here I come!! Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 1, 2008 Share July 1, 2008 if you can afford one, should be no problem getting one or two SB800/SB600, and the wireless commander to trigger them remotely anyway, now i know i have BBB virus but i'm aiming the D300 and 17-55 F2.8 . actually, the thing which makes the biggest impact is my SB800 Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 1, 2008 Share July 1, 2008 imho, the best use of POP up flash is to trigger the whatever off-camera-flashes. it's an el cheapo way (but effective!) to have multiple remote flash system when i do that i set my onboard flash to manual, lowest power setting unless i want some light from it as well then i adjust accordingly. Link to post Share on other sites More sharing options...
Rncw 5th Gear July 1, 2008 Share July 1, 2008 i think only very rich people dun need to find excuses to buy stuff they want. what a good excuse to buy Link to post Share on other sites More sharing options...
Comfy 1st Gear July 2, 2008 Share July 2, 2008 $2999 is in USD. I will check it out in Japan. What I've heard is that its exactly the same as D300, except the FX. The Viewfinder is unique too, unfortunately, at 95%. All accessories of D300 can be use back like MB-D10 and the batt is EN-EL3e. FYI, SB900 Flashgun is also launched. If you go for D700, you better get the SB900. This flashgun is specially made for FX and can reach 200mm. (SB800 only 105mm) One thing I don't understand. Why do they build a built in flash in D700? This is the only Fullframe cam that has a built in pop-up flash as far as I know. Rgds buy oridi then say... i think i buying these.. Link to post Share on other sites More sharing options...
Megaweb Clutched July 2, 2008 Share July 2, 2008 oh ya forget you belong to the very rich people joking ↡ Advertisement Link to post Share on other sites More sharing options...
Carbonics Cold Air Intake System - Full Handmake CF
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
No more Nikons... The End Of A Beautiful Era... don't make it too snappy
Alcades power optimizer
Microsoft to buy solar power in Singapore
Cordless power tool system - which one ?
