Octane Booster
Turbobrick
Hi Guys,
Can anyone advise me on where to get the stuff like Methyl Benzene...... I'm actually wanted to test it out. Read quite alot of this so call "octane booster". [:p]
Sino Chemical? They deal with all sorts of chemicals and alcohols but may require large quantity purchases.
Check yellow pages for contact. [;)]
Can get them in 18 ltr tins if anyone interested.
Toulene is a organic derivative solvent with the same family as the petroluem.
By itself it has a high RON 114 & by adding small doses, it actually boost the octane
levels of our UL98 closer to 100.
High octane reduced multiple detonation inside the engine thaty causes engine knocking or so call pinging.
Pour 4-5 ltrs of toulene into the almost empty tank & then fill it up with regular
UL98 petrol. Problem is how to store tis volatile liquid! [crazy]
Sori but I dun supply only recommend.
If u like u can try several chemical cos. that do, try Sino Chem, Pure Chem,etc...
although they may onli sell u in 200 ltr or 55 gal steel drums.... [:/]
Octane - Does octane rating really affect how my car runs?
Gasoline is a mixture of 20 to 30 different fuels, octane being the heaviest fuel in unleaded gas. A gasoline's octane rating is simply the percentage of octane fuel it contains.
It depends on your car. Indeed cars are designed for a certain octane rating. If you use lower octane rating than that one that your car allows, your car performance will be affected.
The main point to remember is that when your engine knocks or pings during acceleration, your octane is too low. The ideal octane for your car is the lowest grade you can give it without encountering the dreaded knock and ping. Otherwise if you use a higher octane rating you won
Why are you replying to 4 yrs old thread with one liners???? [hur][hur] You did that with the thread on broquet too [hur][hur] ...another one liner newbie trying to chalk up post??? [hur]
he probably think the is EDMW in hardwarezone.
Anyway, just a word of caution, toluene is a control substance in singapore. You can be fined and jailed for "illegal possession"
hi,
anyone tried this before? I chanced upon this at the Carousell, one bottle for ten dollars.
Edited by Lmws214
hi,
No need this,just use V-Power Nitro....
This one really works?? I thought its Shell selling Koyok only leh.. My NA car cannot feel any diff from the ron98.
You are right,N/A Cars not much Difference :mellow: ,but Turbocharged ones...Yes. [thumbsup]  [:)]
  • Praise 3
