Kingcopa 1st Gear August 26, 2008 Share August 26, 2008 I am on T1R. due to some balancing prob, one of my front tyre (passenger side) is seriously worn out. Recently i kena a screw on that tyre and i manage to remove the screw n batch up the tyre. Should i change the tyre (just 1 pcs)? Remaining 3 still look good. ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear August 26, 2008 Share August 26, 2008 standard protocol is change front 2, rotate them to the back. new tieyar in front. Link to post Share on other sites More sharing options...
Kingcopa 1st Gear August 26, 2008 Author Share August 26, 2008 Change 2! change 1 can? $ no enu Link to post Share on other sites More sharing options...
Swiftboi Neutral Newbie August 26, 2008 Share August 26, 2008 get a tyreman to chk all four tyres again maybe the worn out is due to yr alignment, if u want save $$ yr back tyres doing fine then can rotate yr tyre 1st or juz change both front old to new tyres loh.... Link to post Share on other sites More sharing options...
Singer Neutral Newbie August 26, 2008 Share August 26, 2008 Not only it's not adviceable to have a different model of tyres on the same axle, different thread wear of the same model is also not recommended evethough they look 'good' Traction might be compromised - safety Is the damage to your tyre that bad that warrants a complete change? Try changing a set of 2 pieces then. Link to post Share on other sites More sharing options...
Singer Neutral Newbie August 26, 2008 Share August 26, 2008 I adhere to this formula But others claim new tyres go to the rear especially it ride is RWD Link to post Share on other sites More sharing options...
Help1 1st Gear August 26, 2008 Share August 26, 2008 use your spare tyre if it is the same size, very rare to use spare tyres nowadays so if you really want to save, the seriously worn out tyres put back as spare loh... with the spare tyre now working with the rest of 3 tyres, change all 4 when it is due Link to post Share on other sites More sharing options...
Toalson 1st Gear August 26, 2008 Share August 26, 2008 New tyres should go to the rear if it is FWD and vice versa for RWD. But for AWD not sure. There is a write up in almost all tyres manufacturer website. Link to post Share on other sites More sharing options...
Modykoh 1st Gear August 26, 2008 Share August 26, 2008 your 3 tyra how old? if say only few weeks, then maybe can consider. If cover more then 10k. better to change 2. use the other TR1 as spare instead if the profilematch the spare Link to post Share on other sites More sharing options...
Kingcopa 1st Gear August 27, 2008 Author Share August 27, 2008 Tyre is relatively new, less than 1 year mileage abt 20k. Prob is the worn out tyre is puncture by screw. Now batch up Link to post Share on other sites More sharing options...
Modykoh 1st Gear August 27, 2008 Share August 27, 2008 ic ic,,under inflate tyra and wear inner side...? change 2 la...20k almost 50% capital gain liao.. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 27, 2008 Share August 27, 2008 My suggestion to you is change 2 Pcs ↡ Advertisement Link to post Share on other sites More sharing options...
Home repair advice needed
Computer advice needed
RAM/MicroSD issues
RAM/MicroSD issues
Advice on exhaust.
Advice on exhaust.
