Lmf78 Neutral Newbie December 15, 2008 Share December 15, 2008 Hi all, wanna do my white ride before CNY, not very good condition although i DIY groom my car, got scratches and all, would machine polishing help? Dun have a polishing machine, wanna get one but afraid would screw things up, any to recommend? Mine is a kim chi white ride, if not convenient can PM me... ↡ Advertisement Link to post Share on other sites More sharing options...
Kelpie 2nd Gear December 15, 2008 Share December 15, 2008 I also looking for one too..one that hooks up to your ciggy lighter point and you can polish right away. Regards, Link to post Share on other sites More sharing options...
Lmf78 Neutral Newbie December 15, 2008 Author Share December 15, 2008 Those r strong enuff? Dunno how to do it meself therefore wish for the bros/sis here to intro a good groomer who uses machine to polish... Link to post Share on other sites More sharing options...
Kelpie 2nd Gear December 15, 2008 Share December 15, 2008 I suppose the end result will surely be better than using hands. The problem is where to find it? I have came across only a few in e-bay previously but prefer to get it locally. At least spolit or got problem can revert immediately. Regards, Link to post Share on other sites More sharing options...
Jepp3144 Neutral Newbie December 15, 2008 Share December 15, 2008 Bro, if you manage to find one pls PM me....interested Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear December 15, 2008 Share December 15, 2008 Those powered by ciggy lighter point are not strong enough for proper polishing jobs Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 15, 2008 Share December 15, 2008 still better than using hand? Link to post Share on other sites More sharing options...
Lmf78 Neutral Newbie December 15, 2008 Author Share December 15, 2008 Have tried using hands, but got some area like gone case, so wondering if those machines can work... Or any shop i can go to do get a decent job done up by them? one time no hard selling kind shop would be appreciated... Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear December 15, 2008 Share December 15, 2008 Yah, should be better but may cause swirls? Link to post Share on other sites More sharing options...
Rliewky 1st Gear December 15, 2008 Share December 15, 2008 actually autobacs have a bettery operated buffer but understanding is only suitable for applying wax and can only last for a short duration. i think is about an hour, if i recall correctly. will not be enough to do paint correction. for that you will need to use proper buffering machine Link to post Share on other sites More sharing options...
Lmf78 Neutral Newbie December 15, 2008 Author Share December 15, 2008 Yeh saw a few at autobacs, just that this pad n that pad blurs me... intend to find a shop to do the polishing, any to intro? Link to post Share on other sites More sharing options...
Venco25 Neutral Newbie December 15, 2008 Share December 15, 2008 You happen to know if the pads/backing plate of the battery-operated buffer machine can be changed? I haven't got a chance to view it yet. I do have the PC but it's sort of cumbersome to setup just for maintenance work Link to post Share on other sites More sharing options...
Davc Neutral Newbie December 15, 2008 Share December 15, 2008 (edited) http://cgi.ebay.com.sg/In-Car-DC-12V-to-AC...A1%7C240%3A1318 http://www.nextag.com/12v-dc-to-220v-ac-inverter/search-html http://www.dcacpowerinverters.com/220_volt..._inverters.html https://www.samstores.com/Store.asp?CtgID=613 Without a proper machine (DA or Rotary), your choice of pads are limited, you also only have limited power. Check out the links above, you guys think this will work? Only problem is when we polish the bonnet engine need to be off, what if the battery drained out? Edited December 15, 2008 by Davc Link to post Share on other sites More sharing options...
Venco25 Neutral Newbie December 16, 2008 Share December 16, 2008 I wasn't referring to those plugged in to the 12V ciggy plug. Rather, those powered by a battery pack. I understand that such machines are not used for paint correction or any serious work. Just toying with the idea of using such machines for general buffing/application Link to post Share on other sites More sharing options...
Rliewky 1st Gear December 16, 2008 Share December 16, 2008 not too sure. my guess you cannot change the backing plate. if i recall correctly you can change the cover of the pad. Link to post Share on other sites More sharing options...
Blue2 1st Gear December 16, 2008 Share December 16, 2008 I saw carre4 got sell plug in to ciggie type.... mayb u 1 2 check it out.... Link to post Share on other sites More sharing options...
Chickensoup 1st Gear December 16, 2008 Share December 16, 2008 Everytime you polish with machine, it takes off a layer of the paintwork. So cannot do too many times. Link to post Share on other sites More sharing options...
Highway Neutral Newbie December 17, 2008 Share December 17, 2008 hi all my ride is full of stubborn water marks and spots on root, bonnet and rear bonnet. i had tried a few brands of car shampoo and also tried using mild vinegar to clean but it is still there. i tried a car groom services but no good as the water spots are there, it only managed to make the car shinny but not removing the spots. has anyone tried a mobile groom or polisher services that is able to reduce water spots or best is removed all water spots ? any recommendation ? Many thanks ↡ Advertisement Link to post Share on other sites More sharing options...
YouTrip Mobile wallet
New Age Polish --> Chevrolet Portfolio
