Convert to Flipkey
Kungfu
Starting from $50. Also depends whether your car has immobilizer installed or not. If immobilizer is in the picture, it might be harder and more expensive.
Hope this information helps.
Cheers.
Anybody know how much to convert to flipkey?????????????
my friend just did for his toyota rush, cost S$95. his alarm is 4 button kind. not sure model exactly.
did at Soxxi outlet at Marina Square
cheers
Edited by Stickman
I did mine at Sin Ming, no immobilser, $50, duration abt 10mins (excluding waiting) ... hope this helps.
I did mine for $98, last month over@Soxxi, Toh Guan Ave...
Mine was a Swift key; they transferred the immoblizer chip into the new flip key casing.
I did the conversion from a normal (ie cheapo alarm module and key with immo transponder) to flipkey. Sad to say,the flipkey though cool-looking was rather heavy. Also, I accidentally dropped the flipkey a few times, and thats it. The immo chip transplanted to the flipkey still works, but the alarm (lock/unlock) no longer worked. The explanation i can think of is that the flipkey shell is a shell only, so when your existing alarm board is transferred over to the flipkey shell, it may not sit properly (or not secured/ill-fitting/no protected sufficiently). hence when the flipkey is dropped, more damage is done than in the original key/alarm shell.
So bottom line is if you are interested to mod to flipkey, please be rather careful with the handling of the flipkey afterwards.
