Coolant problem
Wpower
The cause can be due to anti freeze mixture too low, water corrosive due to presence of chlorine or combustion gas leaking into the water cooling system
does that mean there is a leak in the air flow somewhere?
if after flushing the whole coolant, this still happens, any idea wads wrong?
IMPT!!!
It can mean 2 things-
1 your red coolant is dirty. flush and refil
2 your coolant is NOT even close to red (maybe green) URGENT! check if the coolant is oily. check if the engine oil is milky. engine oil and coolant run very closely in certain parts of the engine. there MAY be a breach somewhere and the coolant may have been contaminated with engine oil and vice versa. better get it fixed soon before it get s worse- ie. piston heads rust due to water in engine oil, cylinder blows. to be safe, send for check asap. not a small matter.
It means that there maybe a possible minute combustion gases leaking via the cylinder head gasket into the water jacket gallary/jacket areas.
