7seater Clutched June 30, 2009 Share June 30, 2009 Come across different brand tyres and going thru their provided specification found there are differences although is having the same tyre size. Example between Hankook V12 & Federal Evo for 195-55-15 tyre size, we would presume it should have the same 195mm tyre width planting on the ground. I was wrong. Hankook has 164mm width and Federal has 174mm. Full 10mm wider. Hankook 205-50-15 has 172mm width planting on the road. Really surprise me. Just to share. All info provided by the main tyre suppliers themselves. ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 30, 2009 Share June 30, 2009 WOLS Link to post Share on other sites More sharing options...
Rtth84 1st Gear June 30, 2009 Share June 30, 2009 where can the info be found? 195 width doesn't mean contact width anyway. Link to post Share on other sites More sharing options...
7seater Clutched July 4, 2009 Author Share July 4, 2009 You check the links. http://www.federaltire.com/en/images/datas...spec595EVO.html http://shhtyres.com.sg/images/tyres/passen...traHigh_V12.pdf Link to post Share on other sites More sharing options...
EventH 1st Gear July 4, 2009 Share July 4, 2009 difference is in the water longkang The section width is the one that is reflected by the tyre size ... +/- a little. You will get more treadwidth if you get full slicks. ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
