Vibration When Air-Con Cut In
Orange1971
Recently I noticed that my car vibrate when the Air-Con Cut In.
Any suggestion to eradicate this symptom?
when u pop the hood, and then turn on aircon, are you able identify what is causing the vibration?
Could it be the compressor? It may be good to bring it to markcool (at woodlands industrial park) for a check.
How old is your car and mileage ?
Older cars (4th yr) or high mileage cars (close to 100k km) would need to change their engine dampers as they would have harden. This is one of the causes for vibrations.
Either the aircon compressor or the engine mountings.
If you switch off the aircon and still vibrating with no erratic idling in yr rpm, most likely it could be your mountings.
I've the same problem. Mounting is quite new. The vibration is so bad that the whole steering wheel can vibrate. Then air-con slow down then vibration stop. Any idea why?
My car close to 5 yrs, once a while can feel little vibration. May I know how much to change engine mounting?
trying cleaning yr throttle body, sometime its help bcos of the carbon built up that affect the movement of the valve during compressor cut in/out....
mine is manual... same problem... but when i clutch in... no noise... whts the problem?? 9mth car here... 24k mileage.
Hi i have this problem when aircon cuts in.. 08 civic.. any advice?
I have the same problem for my civic FD4M 1.6 when air-con cuts in the rpm drops and take some time to pick it up and during this period it vibrates.my mounting all change but problem still there, end up when to my regular workshop n tell them the problem and they clean my throttle body problem solve, air-con cuts in cant feel any vibration at all and rpm don't drop so much and straight pick up. get your throttle body clean
