Pandaeyes Neutral Newbie July 13, 2009 Share July 13, 2009 Dear bros, I have a problem, need expert advice. Super noob in customising jobs. Jus had my customised job doen for my front bumper. However, after a few weeks, the joining parts started to have waves. According to my friends, this is because the putty that the shop applied has dried up. Now, I called the company and they said they will repair it for me. My question is, will the putty dry up again and again, the waves happen? The company said it will not. Will the waves appear again? Is it worth the trip down to the shop to ask them to rectify or am I just watsing my time? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Jaguar Neutral Newbie July 15, 2009 Share July 15, 2009 Where did you have the bumper done up, Was the putty you mention is the Fiber butty done by Body kit shop or painting shop. Link to post Share on other sites More sharing options...
Icekitten Clutched July 20, 2009 Share July 20, 2009 There will be lesser, not no chance of the waves coming back. Reason for the waves is due to the fibre putty 'settling' therefore it sinks in and creates an imprint or wavy outlook. It's quite normal. But how noticeable the imprint or wave is all depends on the skill of the bodykit shop and also spray shop if you did ur spray elsewhere. Coz the spray shop is responsible for sanding down the fibre putty before spraying. Eg. Some ppl complain that operated bonnets (bonnets cut and joined with a vent) will have that imprint at the cut and join part. You know, the vent will pong out. However, I have changed 3 types of operated bonnets before and even those who've seen it all agree that mine looks ok. Never even went for touch-up. But I've seen operated bonnets on other cars with shoddy workmanship before so I know the issue does exist. My last full-body spray, I gave the spray shop (different from my bodykit shop) a newly-operated bonnet to spray, they warned me about the imprint thingie too. And said if it appears to go back for touch-up. They will layer putty and sand over again. But so far so good. Link to post Share on other sites More sharing options...
Bing Neutral Newbie August 9, 2009 Share August 9, 2009 Dear bros, I have a problem, need expert advice. Super noob in customising jobs. Jus had my customised job doen for my front bumper. However, after a few weeks, the joining parts started to have waves. According to my friends, this is because the putty that the shop applied has dried up. Now, I called the company and they said they will repair it for me. My question is, will the putty dry up again and again, the waves happen? The company said it will not. Will the waves appear again? Is it worth the trip down to the shop to ask them to rectify or am I just watsing my time? Thanks! You need to find a good paint shop. Need a good punty first then the paint coat. Link to post Share on other sites More sharing options...
Kianbeng Clutched September 3, 2009 Share September 3, 2009 icekitten is correct. It's because the putty is not dry enough. The best is if the putty work is left to dry overnight or use heat to speed up. Then you'll see the putty will sink in a bit. Then by right should putty again and sand down. All these should be done before the spray paint. Link to post Share on other sites More sharing options...
Mikeyeo Clutched September 5, 2009 Share September 5, 2009 Dear bros, I have a problem, need expert advice. Super noob in customising jobs. Jus had my customised job doen for my front bumper. However, after a few weeks, the joining parts started to have waves. According to my friends, this is because the putty that the shop applied has dried up. Now, I called the company and they said they will repair it for me. My question is, will the putty dry up again and again, the waves happen? The company said it will not. Will the waves appear again? Is it worth the trip down to the shop to ask them to rectify or am I just watsing my time? Thanks! The installer after applying the 1st layer of putty along the joint, should have laid a fibreglass lining with appropriate adhesive to bridge the joint in preventing differential movement. After the fibreglass lining is try, then proceed with the spray coating. It's similar to putting up gypsum board panell for false wall. The contractor would either lay a continuous tape or fibreglass strip to bridge the entire joint and apply putty to level the wall. This will eliminate possible hairline crack along the joint due to movement. Link to post Share on other sites More sharing options...
Pandaeyes Neutral Newbie September 5, 2009 Author Share September 5, 2009 The installer after applying the 1st layer of putty along the joint, should have laid a fibreglass lining with appropriate adhesive to bridge the joint in preventing differential movement. After the fibreglass lining is try, then proceed with the spray coating. It's similar to putting up gypsum board panell for false wall. The contractor would either lay a continuous tape or fibreglass strip to bridge the entire joint and apply putty to level the wall. This will eliminate possible hairline crack along the joint due to movement. Thx! I went to another shop to rectify the problem. Chuan Paint. Not too bad. Much better than the body kit shop... Anyway, just to side track. Which companies are worth recommending for customising bodykit? Link to post Share on other sites More sharing options...
Yuan 6th Gear September 6, 2009 Share September 6, 2009 Thx! I went to another shop to rectify the problem. Chuan Paint. Not too bad. Much better than the body kit shop... Anyway, just to side track. Which companies are worth recommending for customising bodykit? You can go D-Mix at Eunos Industrial Park or Yun Design at Sungei Kadut. ↡ Advertisement Link to post Share on other sites More sharing options...
I tried Sliplo and here's what I think.
Order bodykit from taobao
Customised Car Decals and Vinyl Stickers.
Bodykit for Mazda 3
Bodykit for Mazda 3
Where workshop do remount of bodykit ?
Where to get authentic customised 3M Car mat in JB?
Pics of Henderson Waves
Leon Cupra R Bodykit for Seat Toledo
