Tires Width vs Tires Diameter
Ogima
hello comrades,
would appreciate some inputs here. thank you in advance.
Tire Width vs Tire Diameter
same size of rims with same tire tread design...which of the below will have a higher FC ?
a) 245/50R19 = wider tires
b) 235/55R19 = higher sidewall, bigger overall diameter.
Speedo Deviation vs Total Distance Travelled.
if with the above latter Oversize tires, the speedometer displacement is 5.6% from my stock tire configuration 225/60R17.....ie when my speedo reads 100kmh, my actual speed is 105.6kmh.
from the below link, i found that most parameters had a deviation of 5.6% (diameter, circumference etc.)
http://www.miata.net/garage/tirecalc.html
now the question is.... if i use the Oversize tires, when my meter trip A for One Full Tank is 500km....does it also meant that the actual distance covered is 528km (plus the 5.6%) ?
awaits your kind contribution. [flowerface]
Technically yes, provided u manage to hit 528km in 1 full tank. Chances are your pickup may slack endup more fuel comsumption.
You may drive over the speed limit without notice it.
Confirm cannot, upsize above 3%. In order for your anti-lock brakes to work properly. Traction and stability control systems can also be adversely affected.
Either sizes for you...
1. 245/50/18
2. 235/45/19
