Verve 1st Gear October 16, 2009 Share October 16, 2009 i just changed to a used cs3 - 06 model.the fc is onli 9km/l - is this normal - i am quite heavy footedmy full tank is 375 km for 41 litres.cs 3 owners care to share your full tank mileage or what could be wrong,just changed oil, spark plugs and air filter.thank you all. hoping to hit at least 11 km / l ↡ Advertisement Link to post Share on other sites More sharing options...
Creative_tec 2nd Gear October 16, 2009 Share October 16, 2009 i just changed to a used cs3 - 06 model. the fc is onli 9km/l - is this normal - i am quite heavy footed my full tank is 375 km for 41 litres. cs 3 owners care to share your full tank mileage or what could be wrong, just changed oil, spark plugs and air filter. thank you all. hoping to hit at least 11 km / l I clock 450 for full tank... also manual CS3 Link to post Share on other sites More sharing options...
Verve 1st Gear October 16, 2009 Author Share October 16, 2009 sorry forgot to add, mine is cvt Link to post Share on other sites More sharing options...
Civic6656 1st Gear October 16, 2009 Share October 16, 2009 (edited) sorry forgot to add, mine is cvt Your mileage is normal since you are heavy footed + with CVT gearbox. My previous lancer achieved only 8km/L. Edited October 16, 2009 by Civic6656 Link to post Share on other sites More sharing options...
Kawarides Neutral Newbie October 16, 2009 Share October 16, 2009 For your fc should be normal since you are quite heavy footed, mine is a manual and the FC always depends mostly on driving pattern and road travelled. My experience after 2 yrs can be 15KM/L with 80% HW and 20%city driving or can be as low as 12km/L for the reverse . I am a light footer cos I do not find much joy flooring a stock bread and butter car. IMO ,CVT gearbox will have a better FC compared to normal auto trans but you need to drive gently in order to have that advantage. Link to post Share on other sites More sharing options...
Verve 1st Gear October 16, 2009 Author Share October 16, 2009 thanks, this is a bread and butter car but force of habit hrf. maybe i watch it and see how i can improve things. i travel 3000 km a month. Link to post Share on other sites More sharing options...
Jolie888 Clutched October 16, 2009 Share October 16, 2009 Manual Mit CS3 can get anywhere between 10-12 km/L. C&C claims 12 km/L, but that one must be very light footed liao. CVT's transmission loss >> manual. So getting 9 km/L or thereabouts is not surprising. Link to post Share on other sites More sharing options...
Diesel 1st Gear October 16, 2009 Share October 16, 2009 My 3-yr old CVT getting around 11(+/-1)km/L. Pure stock with 16" lightweight rims. Weekdays confirm use KPE twice (Bartley to ECP & back). CVT cannot be heavy-footed otherwise FC really drops significantly. Gd thing about the lancer CVT is max torque @ 2,700rpm, so no need HRF to get the car moving fast from still Now got belt whining noise from cold start Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 16, 2009 Share October 16, 2009 i just changed to a used cs3 - 06 model. the fc is onli 9km/l - is this normal - i am quite heavy footed my full tank is 375 km for 41 litres. cs 3 owners care to share your full tank mileage or what could be wrong, just changed oil, spark plugs and air filter. thank you all. hoping to hit at least 11 km / l Most of the time can clock >500km per full tank until the light comes on, then top up till full is around 38 +/- litres. Mine is manual CS3. If driven gently can get >15km/l, but nowadays I'm getting around 13+km/l with slightly aggressive driving. Link to post Share on other sites More sharing options...
Alfisti168 1st Gear October 16, 2009 Share October 16, 2009 Mitsubishi CS3 - what car is that? Link to post Share on other sites More sharing options...
Lanceraz Clutched October 16, 2009 Share October 16, 2009 lancer glx Link to post Share on other sites More sharing options...
Surferguy1978 1st Gear October 16, 2009 Share October 16, 2009 For your fc should be normal since you are quite heavy footed, mine is a manual and the FC always depends mostly on driving pattern and road travelled. My experience after 2 yrs can be 15KM/L with 80% HW and 20%city driving or can be as low as 12km/L for the reverse . I am a light footer cos I do not find much joy flooring a stock bread and butter car. IMO ,CVT gearbox will have a better FC compared to normal auto trans but you need to drive gently in order to have that advantage. that right! mine is around the same as yours. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear October 16, 2009 Share October 16, 2009 (edited) My dad's CS3 is CVT too, with 168K of milleage clocked. Running on 15" Advanti rims & Falken ST115 195/60/R15; minor performance mods like operated muffler & after-market air filter, his FC is constantly at 11-12km/L. His driving style is spirited, with 70% highway most of the time. Please make sure that your tyre pressure is correct and your engine oil is not overfilled. Every oil change only require exactly 3 quarts (0.946L x 3) of engine oil, and don't use any engine oil thicker than 5W40. When changing spark plugs,ensure it's the correct heat range, eg: Denso is IK20, NGK is using size 6. Pls also make sure to change your CVT fluid,use nothing more than 4L. Cheers Edited October 16, 2009 by Mr_biscuit Link to post Share on other sites More sharing options...
Verve 1st Gear October 16, 2009 Author Share October 16, 2009 thanks for the tip, maybe the heat range for the spark plugs are suspect, and the cvt fluid, any idea how much to change the cvt fluid. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear October 17, 2009 Share October 17, 2009 For Mitsubishi CVT Fluid, I always buy the original "Diaqueen white 4L bottle" from stockist, Min Ghee, should be about $30. Thereafter, just bring to your normal workshop to change. Link to post Share on other sites More sharing options...
Maroon5 5th Gear October 18, 2009 Share October 18, 2009 i just changed to a used cs3 - 06 model. the fc is onli 9km/l - is this normal - i am quite heavy footed my full tank is 375 km for 41 litres. cs 3 owners care to share your full tank mileage or what could be wrong, just changed oil, spark plugs and air filter. thank you all. hoping to hit at least 11 km / l its normal. u can go lighter on ur foot to get the 11km. mine is also 06 manual...good fc. Link to post Share on other sites More sharing options...
Yuan 6th Gear October 18, 2009 Share October 18, 2009 i just changed to a used cs3 - 06 model. the fc is onli 9km/l - is this normal - i am quite heavy footed my full tank is 375 km for 41 litres. cs 3 owners care to share your full tank mileage or what could be wrong, just changed oil, spark plugs and air filter. thank you all. hoping to hit at least 11 km / l Mine is CVT. Clocked 450-480 km for a full tank. Heavy footer also. Link to post Share on other sites More sharing options...
Fatfatgetz Neutral Newbie October 18, 2009 Share October 18, 2009 my is 07 manual lancer glx averge can clock 550 when light up wif 16" rim and light alloy pulley and after market air filter ↡ Advertisement Link to post Share on other sites More sharing options...
MAZDA 6
MAZDA 6
[Official] 2024 8th Generation BMW 5 Series (G60)
2026 8th Generation Lexus ES
