Sammy_koh Neutral Newbie October 19, 2009 Share October 19, 2009 Hi Bros, Read on hurricane website. using it can expect 10% more milege really true? also claims its as good as open pod performance? no oling needed so it must be better than K&N. Any bros able to comfirm on this. considerin though ↡ Advertisement Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear October 19, 2009 Share October 19, 2009 Read on hurricane website. using it can expect 10% more milege really true? Definitely No, cos your engine 'breathes' easier so you may tend to step on your accelerator more often so mileage depends on you. also claims its as good as open pod performance? No idea. Haven't try open pod yet. no oling needed so it must be better than K&N. No oiling if you getting the stainless steel type. SS type just need to use air gun and blow it clean. Conclusion: IMHO: One can definitely find the difference between stock and non-stock air filter(I definitely won't be changing back so soon). But since all non-stock filters are not as good as filtering compared to stock, you gota go change engine oil more regularly. Link to post Share on other sites More sharing options...
Zhihao 1st Gear October 19, 2009 Share October 19, 2009 i dun really feel all the diff u mentioned... jus take it that you r buying a filter that you dun have to change forever lor... Link to post Share on other sites More sharing options...
Sammy_koh Neutral Newbie October 19, 2009 Author Share October 19, 2009 hmm u using hurricane bro? guess like tat stock should be good enough. Link to post Share on other sites More sharing options...
SaNibOy Clutched October 19, 2009 Share October 19, 2009 Im using hurricane drop in coming 5 years already. No complaints so far. Makes my near 2 ton car better on pickup. Link to post Share on other sites More sharing options...
Zhihao 1st Gear October 19, 2009 Share October 19, 2009 maybe its jus me... dun really feel the diff lei... Link to post Share on other sites More sharing options...
D3badge 6th Gear October 19, 2009 Share October 19, 2009 on mid to high range RPM, engine feel smoother not so rough and sound better that all (own experience) Link to post Share on other sites More sharing options...
ILNivleK Neutral Newbie October 21, 2009 Share October 21, 2009 If you want open pod and on AT transmission, be prepared to lose low-end. On HKS or other performance exhaust will lose even more low end. I'm on HKS + Hurricane Drop in. Low end loss can be minimised by tuning and keeping rim size small, my rim size is 15". Cheers. Link to post Share on other sites More sharing options...
Geminik Neutral Newbie October 22, 2009 Share October 22, 2009 If you want open pod and on AT transmission, be prepared to lose low-end. On HKS or other performance exhaust will lose even more low end. I'm on HKS + Hurricane Drop in. Low end loss can be minimised by tuning and keeping rim size small, my rim size is 15". Cheers. I dunno anything abt exhaust, care to enlighten why HKS or other performance exhaust reduce low end performance? Cos i thinking of changing to HKS for my AT vios Link to post Share on other sites More sharing options...
SaNibOy Clutched October 22, 2009 Share October 22, 2009 Bcos performance exhaust is a straight thru setup with big diameter. For MT cars, tis is good but not for AT cars. Unless the diameter is smaller. Same goes for extractor. AT use 4-2-1 better rather than 4-1. Link to post Share on other sites More sharing options...
ILNivleK Neutral Newbie October 23, 2009 Share October 23, 2009 I dunno anything abt exhaust, care to enlighten why HKS or other performance exhaust reduce low end performance? Cos i thinking of changing to HKS for my AT vios Are you in VOGS? You can find out more there. I'm in there too. If you intend to change to HKS, low end will suffer, especially AT car. You must be able to endure the HKS exhaust roar. Haha. Esp if you got CO, wait CO will complain. To minimise low end loss, you can 1. change extractor from stock 4-1 to aftermarket 4-1, or a 4-2-1 even better. Take note that aftermarket 4-1 and 4-2-1 not LTA compliant. 2. add CAI. I have CAI, not sure if it helps but at night when the air is cool, pickup must better. 3. Keep rims at 15". 4. Add piggyback and tune. I'm on Unichip Q. I've gained 12bhp more than the stock 109bhp as stated for the current belta vios with the above setup after dyno-ing. Hope the information above helps. Cheers. Link to post Share on other sites More sharing options...
Artsavry Neutral Newbie October 23, 2009 Share October 23, 2009 unichip q is definitely a good investment Link to post Share on other sites More sharing options...
Speddevil Neutral Newbie October 23, 2009 Share October 23, 2009 yes agreed Link to post Share on other sites More sharing options...
Geminik Neutral Newbie October 23, 2009 Share October 23, 2009 Are you in VOGS? You can find out more there. I'm in there too. If you intend to change to HKS, low end will suffer, especially AT car. You must be able to endure the HKS exhaust roar. Haha. Esp if you got CO, wait CO will complain. To minimise low end loss, you can 1. change extractor from stock 4-1 to aftermarket 4-1, or a 4-2-1 even better. Take note that aftermarket 4-1 and 4-2-1 not LTA compliant. 2. add CAI. I have CAI, not sure if it helps but at night when the air is cool, pickup must better. 3. Keep rims at 15". 4. Add piggyback and tune. I'm on Unichip Q. I've gained 12bhp more than the stock 109bhp as stated for the current belta vios with the above setup after dyno-ing. Hope the information above helps. Cheers. Thanks for the info I'm currently on stock, changing extractor may not be a good thing when coming to inspection. I'm interested in getting CAI and unichip, do u have any recommendation and estimation cost? I'm using 17" lightweight rims thou thanks Link to post Share on other sites More sharing options...
Sammy_koh Neutral Newbie October 23, 2009 Author Share October 23, 2009 any bros know wats e easiest way to make e car up a few horses e fastest way? without changiing too much of the current setup? so have change to iriduim sparkies + 1 horse. change to redline full syn oil dun tink even a horse leg. lower e springs not sure e horse can run faster on straight but feel can go faster around e turn. still using stock 15inch rims. wat else can i do? looking at $1000 to buy e most number of horses possible Link to post Share on other sites More sharing options...
ILNivleK Neutral Newbie October 23, 2009 Share October 23, 2009 any bros know wats e easiest way to make e car up a few horses e fastest way? without changiing too much of the current setup? so have change to iriduim sparkies + 1 horse. change to redline full syn oil dun tink even a horse leg. lower e springs not sure e horse can run faster on straight but feel can go faster around e turn. still using stock 15inch rims. wat else can i do? looking at $1000 to buy e most number of horses possible Any bros here can correct me if I'm wrong, I think changing your extractor and exhaust will give you a number of bhp improvement. For my case, after i changed my extractor and exhaust, i dyno-ed and got 5bhp above stock. But it's best to get a piggyback to get a significant improvment in bhp and/or torque. Cheers. Link to post Share on other sites More sharing options...
Tohto Hypersonic October 23, 2009 Share October 23, 2009 any bros know wats e easiest way to make e car up a few horses e fastest way? without changiing too much of the current setup? so have change to iriduim sparkies + 1 horse. change to redline full syn oil dun tink even a horse leg. lower e springs not sure e horse can run faster on straight but feel can go faster around e turn. still using stock 15inch rims. wat else can i do? looking at $1000 to buy e most number of horses possible With $1000, can go for unichip. You will get a few horses. Link to post Share on other sites More sharing options...
ILNivleK Neutral Newbie October 23, 2009 Share October 23, 2009 Thanks for the info I'm currently on stock, changing extractor may not be a good thing when coming to inspection. I'm interested in getting CAI and unichip, do u have any recommendation and estimation cost? I'm using 17" lightweight rims thou thanks If you do piggyback with only CAI + your current mods, I think the increase in bhp will not be that significant. It's the extractor and exhaust that makes the significant difference. CAI you can DIY, or people can do for you between 50-100, depending on type of tube you want. For piggyback, Unichip Q cost around 800-900 with dyno-tuning. It would be better if you can find a second hand one for ard 300-400. Dyno-tuning will cost 100 per hour for rental of dyno-machine, plus tuner fee, which can be between 200-300? Road-tuning should be cheaper, only tuner feel. Cheers. ↡ Advertisement Link to post Share on other sites More sharing options...
Aircon Cabin Filter
Aircon Cabin Filter
Air Purifier Discussion - tips and info
DIY engine oil change
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
TRD Engine Air Filter
