Junyi Neutral Newbie December 2, 2009 Share December 2, 2009 Guys, for converting auto to manual what should i get ah? is it possible to buy from scrap yard? Gear box, clutch, the gear stick, speedo meter, ECU? normally how much will i be expecting to pay for those parts and labour? If need to get the manual ECU means my original key will nt work? Did i miss out anything? ↡ Advertisement Link to post Share on other sites More sharing options...
Creative_tec 2nd Gear December 2, 2009 Share December 2, 2009 Guys, for converting auto to manual what should i get ah? is it possible to buy from scrap yard? Gear box, clutch, the gear stick, speedo meter, ECU? normally how much will i be expecting to pay for those parts and labour? If need to get the manual ECU means my original key will nt work? Did i miss out anything? what car are you converting. think twice before doing the convertion. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear December 2, 2009 Share December 2, 2009 (edited) I would suggest you to continue to drive your auto car until you intend to change your ride.. Thereon, you purchase a manual ride.. Just my opinion but it's up to you.. Edited December 2, 2009 by Ladykillerz Link to post Share on other sites More sharing options...
Kangadrool Supersonic December 2, 2009 Share December 2, 2009 Guys, for converting auto to manual what should i get ah? is it possible to buy from scrap yard? Gear box, clutch, the gear stick, speedo meter, ECU? normally how much will i be expecting to pay for those parts and labour? If need to get the manual ECU means my original key will nt work? Did i miss out anything? Cheaper and more worthwhile with peace of mind - just replace auto car to manual one. Link to post Share on other sites More sharing options...
Tempus Neutral Newbie December 2, 2009 Share December 2, 2009 in the first place if u had paid more for an auto car (auto cars normally more ex than manual rite ??) and now u paying even more to convert to manual ? might as well just sell and buy manual car ?!?! Link to post Share on other sites More sharing options...
Bigg 1st Gear December 2, 2009 Share December 2, 2009 its a very tedious process and many sleepless nights. i advice against it. Link to post Share on other sites More sharing options...
Jimcheam Neutral Newbie December 2, 2009 Share December 2, 2009 (edited) ya better not.. 1st thing u going to sunk alot of money in this auto to manual conversion project 2nd - risk of the car getting damaged after conversion (need to repair spent more $$) 3rd - might not be able to re sell the car. Therefore it is better to buy a factory fitted manual tranny car..unless u have 101% faith in the workshop that is doing the modification and you got alot of yu$$of to give away... Edited December 2, 2009 by Jimcheam Link to post Share on other sites More sharing options...
Observer 4th Gear December 2, 2009 Share December 2, 2009 most likely is some car he aim sibei long but only produce auto lor Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 3, 2009 Share December 3, 2009 Guys, for converting auto to manual what should i get ah? is it possible to buy from scrap yard? Gear box, clutch, the gear stick, speedo meter, ECU? normally how much will i be expecting to pay for those parts and labour? If need to get the manual ECU means my original key will nt work? Did i miss out anything? Bah, piss easy and straightforward job. What you will need: 1) Manual g/box (the shifter, cables etc should be part of this). 2) Manual ECU (easiest way) 3) Pedal set (you won't be able to attach just a clutch pedal. you need to get the entire set). What you may need that won't come with the above: 1) Fittings for clutch cable Prices I can't tell you. I don't know the SG rates for all of this, but your key will work as your immobiliser transponder is not part of the ECU. If you've ever had to shift a gearbox you'll realise how much heavy lifting is needed, but technically, its very easy. Link to post Share on other sites More sharing options...
DMC Neutral Newbie December 3, 2009 Share December 3, 2009 you also need to get approval from LTA. Prior to that, you need to have all the documents - official from the company confirm it suit your car model (safety reasons)/info on the gear,installation, etc.. not easy wor.. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged December 4, 2009 Share December 4, 2009 i have seen my mech in malaysia doing it. they told me its a simple job. 1 man can do it within 2 days. but the car was kelisa, using cab so i think ECU not involved.... u may wanna check with LTA for the local regulation b4 doing it. Link to post Share on other sites More sharing options...
Mogu Neutral Newbie December 7, 2009 Share December 7, 2009 Guys, for converting auto to manual what should i get ah? is it possible to buy from scrap yard? Gear box, clutch, the gear stick, speedo meter, ECU? normally how much will i be expecting to pay for those parts and labour? If need to get the manual ECU means my original key will nt work? Did i miss out anything? It is possible to get the half cut one to convert, however it's best to check with your mechanic and confirm he is able and confident to do it. Firstly, labour is not cheap. The ECU harness may be slightly different too. Link to post Share on other sites More sharing options...
Mogu Neutral Newbie December 7, 2009 Share December 7, 2009 (edited) i have seen my mech in malaysia doing it. they told me its a simple job. 1 man can do it within 2 days. but the car was kelisa, using cab so i think ECU not involved.... u may wanna check with LTA for the local regulation b4 doing it. ECU should play a part. Edited December 7, 2009 by Mogu Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged December 7, 2009 Share December 7, 2009 ECU should play a part. huh?? those old car running on carburettor got ecu?? Link to post Share on other sites More sharing options...
Creative_tec 2nd Gear December 7, 2009 Share December 7, 2009 you also need to get approval from LTA. Prior to that, you need to have all the documents - official from the company confirm it suit your car model (safety reasons)/info on the gear,installation, etc.. not easy wor.. Normally pple will just convert and go for their inspection as per normal. LTA side do not really care about auto-manual conversion. However, it will be real hard work if you are thinking of changing your log card data from auto to manual. I would say its near impossible. Link to post Share on other sites More sharing options...
Cwinedine 1st Gear December 7, 2009 Share December 7, 2009 I saw a Mitsubishi FTO converted to Manual ride with turbo kit...droolz man!And that car dun come in Manual somemore! Link to post Share on other sites More sharing options...
Thugstercena Clutched December 7, 2009 Share December 7, 2009 its better to stick to auto until u change ur ride bro. why convert to manual when people are trying to convert CTR to auto? :) Link to post Share on other sites More sharing options...
Pursue Neutral Newbie December 15, 2009 Share December 15, 2009 if have spare cash can try. Think if your mechanic is good is no prob except the admin part. ↡ Advertisement Link to post Share on other sites More sharing options...
Where to get Workshop Manual
Reputable like Lye Design in Amk Auto-point
Bad Auto Dealer - Salesman!
Conversion to a Welcab
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
