Kurty Supercharged January 24, 2010 Share January 24, 2010 hi, wish to ask some questions pertaining to HU. Using a stock clarion HU, been airing mp3 from fm transmitter but find the sound quality still as suck. stock HU has AUX channel but the funny part is no ports. my questions: is it possible to find installer who can help to make an aux output? using a preamp with aux, could that allow me to connect my mp3 player for music? i know.. many may say to change a new HU that could support that, my stock is a 2 din and it seems i only using it as a device for mp3.. not even cd, already own a garmin gps.. so too gd, might be overkill in my scenario... pls advise. ↡ Advertisement Link to post Share on other sites More sharing options...
Charleslim Neutral Newbie January 24, 2010 Share January 24, 2010 most FM transmitter can only transmit audio frequency from 100Hz-15000Hz, while human ear can hear 20hz - 20000hz, that's why it's never as good as CDs. For your case you can go to any car audio shop to install the aux cable, mostly probably at the back of your HU. If your HU doesn't support Ipod, then you will need to control from the Ipod itself. You need to be aware that Ipod does not produce the best MP3 playback quality, normally a CD of MP3 can do better. Link to post Share on other sites More sharing options...
Kurty Supercharged January 24, 2010 Author Share January 24, 2010 For your case you can go to any car audio shop to install the aux cable, mostly probably at the back of your HU. If your HU doesn't support Ipod, then you will need to control from the Ipod itself. You need to be aware that Ipod does not produce the best MP3 playback quality, normally a CD of MP3 can do better. thanks for the valuable advise. so it can be done but my next worries is that my hu don't have aux channel... initially, it has but i just don't know how to set it... without aux channel, can it still be done? is it using this cable? 3.5mm AUX audio to AV RCA CABLE Link to post Share on other sites More sharing options...
Yzygold Neutral Newbie February 8, 2010 Share February 8, 2010 If your headunit accepts rca inputs behind u may be able to use that cable ↡ Advertisement Link to post Share on other sites More sharing options...
