Tianmo Hypersonic July 17, 2010 Share July 17, 2010 anybody know where I can get tools to gap my spark plugs? thank you many many ↡ Advertisement Link to post Share on other sites More sharing options...
SaNibOy Clutched July 17, 2010 Share July 17, 2010 Autobacs or those uncle shops selling oil and parts. Not tat ex. Link to post Share on other sites More sharing options...
Anakusop Clutched July 17, 2010 Share July 17, 2010 Gapping spark plugs can enhance the performance? Any side effects? Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 18, 2010 Author Share July 18, 2010 thanks Bro will go try see if can get. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 18, 2010 Author Share July 18, 2010 seriously I don't know, but just trying out. Link to post Share on other sites More sharing options...
Weiming 1st Gear July 18, 2010 Share July 18, 2010 Modern spark plugs should come pre-gapped but if you are using those long-lasting types like Iridium etc., then it might be good to check the gap (different cars have different gap distance, check car manual for yours) once a year for peak performance. You can buy such a tool from Ebay: Spark plug gap tool Link to post Share on other sites More sharing options...
Mini-itx Clutched July 18, 2010 Share July 18, 2010 (edited) Gapping spark plugs can enhance the performance? Any side effects? Yes, increasing the spark gap can increase performance due to longer spark. However, this also means a higher voltage is needed to break down the air resistance and create the spark. Stock ignition may not be able to produce enough voltage and hence causing misfire. If you are using aftermarket ignition systems from brands like MSD, Crane, Mallory, you should experiement with increasing the gap to improve performance. I just tried increasing the gap to 1.1mm and the performance improvement is very obvious with my Mallory coil. Of course, downside with more powerful spark and shortening spark plug's lifespan. Other methods to increase performance is side gapping. I also do that to my NGK iridium plugs. Edited July 18, 2010 by Mini-itx Link to post Share on other sites More sharing options...
Mini-itx Clutched July 18, 2010 Share July 18, 2010 anybody know where I can get tools to gap my spark plugs? thank you many many Autobacs has it. Around $5-$6 Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 18, 2010 Author Share July 18, 2010 Autobacs has it. Around $5-$6 thanks bro tomorrow maybe drop by autobacs BB take a look! Link to post Share on other sites More sharing options...
DonNuTs 1st Gear July 18, 2010 Share July 18, 2010 dun overgap it. otherwise the plug might nt even fire. get the feeler type(the other is the wire type), easier and better to set ur own required gap. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 19, 2010 Author Share July 19, 2010 Autobacs has it. Around $5-$6 thanks bro, got it at autobas BB S$4.60. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 19, 2010 Author Share July 19, 2010 actually mine plugs are stock plus with 1.1mm gap, I wanted to gap down to 1mm or 0.9mm for my CNG igintion ↡ Advertisement Link to post Share on other sites More sharing options...
Where to modify seat rail/bracket?
Where to mod fuel needle?
Where to get those plastics that allow your to stick the road tax/decal on screen
Tool to change Spark Plug
Wheel Spacer, where to buy?
Where you cut your hair?
Going to Batam. Where to park overnight ?
