Rationalexuberance 4th Gear August 4, 2010 Share August 4, 2010 experts out there.. what are the pros and cons on ignition boosters? supposed to improve ignition with complete combustion but does it affect ECU? affect spark plugs life span? affect ignition coil life span? Please share, cheers!! ↡ Advertisement Link to post Share on other sites More sharing options...
SaNibOy Clutched August 11, 2010 Share August 11, 2010 Pros ----> power! Cons ----> Ur coils may go up the lorry if current too high. Link to post Share on other sites More sharing options...
Mini-itx Clutched August 11, 2010 Share August 11, 2010 ONE WORD: TRASH... If you really want more poweful sparks, invest in a proper ignition system and better coils. Link to post Share on other sites More sharing options...
Kurty Supercharged August 22, 2010 Share August 22, 2010 one say power while the other say thrash. so which is which? Link to post Share on other sites More sharing options...
Mini-itx Clutched August 23, 2010 Share August 23, 2010 ITs trash trash trash. If you want yo boost your ignition, you need a proper CDI. Then increase your spark plug gap. And you will get much stronger spark and better combustion and more power. But then, its EXPENSIVE!! For a 4 cylinder car, you need something like a MSD DIS4 ignition module and its $800-$1K!! M&W makes good ignition units too!! Link to post Share on other sites More sharing options...
Rationalexuberance 4th Gear August 23, 2010 Author Share August 23, 2010 ITs trash trash trash. If you want yo boost your ignition, you need a proper CDI. Then increase your spark plug gap. And you will get much stronger spark and better combustion and more power. But then, its EXPENSIVE!! For a 4 cylinder car, you need something like a MSD DIS4 ignition module and its $800-$1K!! M&W makes good ignition units too!! maybe not considered trash lah, but i agree it's expensive, unless one thinks it's worthwhile. I think i remain stock, just change whenever needed. Anyway i dun race. Thanks for the sharing Mini-itx! Link to post Share on other sites More sharing options...
Mini-itx Clutched August 23, 2010 Share August 23, 2010 Your coil mainly takes in 12V and output to around 20KV. In order to achieve such high voltage, it needs around 150:1 turns ratio. This means the secondary windings in the coil is extremely thin (something like your hair) and very little current. Ignition booster supply slightly higher voltage 15-18V and make your secondary voltage higher to around 24KV. Slightly more current as well. Slightly better but you risk burning out other stuffs in your car because of the 15-18V. So a better solution? CDI and better coils. CDI uses capacitor to charge from 12V to 400-500V. And "racing" coils uses thicker wires of lower resistance and around 100:1 turns ratio or lower. When the CDI supply 400V to your coil, the output becomes 40KV, much more than any ignition booster out there. Much higher power output as well. With such high voltage, you can open up your spark plug gap and still achieve an even stronger than stock spark and hence better combustion and more power. Down side of CDI is cost...... ITs EXpENSIVE...... Link to post Share on other sites More sharing options...
Carer 2nd Gear August 24, 2010 Share August 24, 2010 CDI timing per ignition is very very short, about 50-80 Link to post Share on other sites More sharing options...
Mini-itx Clutched August 24, 2010 Share August 24, 2010 (edited) CDI timing per ignition is very very short, about 50-80 Edited August 24, 2010 by Mini-itx Link to post Share on other sites More sharing options...
Carer 2nd Gear August 24, 2010 Share August 24, 2010 To overcome this shorter ignition time, most CDI systems are actually multi-spark at low RPMs though (>3K RPM). This actually aids combustions and cranking. CDI is now preferred over TCI because it can produce multiple hotter pulses. CDI runs at a higher temperature and it is prone to failure. a CDI also cost much more than TCI. in short, car manufacturers will not be bothered with CDI if it is not needed since most cars redline at 6.5k rpm - 8k rpm. To sum up, just stick to TCI la. it produces better fuel consumption and is proven to last longer. cheaper.. in fact, u can even DIY it. Link to post Share on other sites More sharing options...
Mini-itx Clutched August 24, 2010 Share August 24, 2010 CDI runs at a higher temperature and it is prone to failure. a CDI also cost much more than TCI. in short, car manufacturers will not be bothered with CDI if it is not needed since most cars redline at 6.5k rpm - 8k rpm. To sum up, just stick to TCI la. it produces better fuel consumption and is proven to last longer. cheaper.. in fact, u can even DIY it. Well...... it all comes down to how much $$$ you have lor. CDI is really not cheap esp. when you have more than 4 cylinders..... ↡ Advertisement Link to post Share on other sites More sharing options...
More financial support from Government for palliative care from 2024: Ong Ye Kung
Migrating down under? Come share your experiences
The Best Cooling Measures: Ice Cream! 😂
Come Share Your View on "Car-Lite City"
