Billcoke 2nd Gear October 24, 2010 Share October 24, 2010 I've a few old Eneloop in my drawers, wanted to use a multimeter to measures their capacity in mA. According to some forums, using multimeter to test the batteries can cause the eneloop to burn, is that true?? ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear October 24, 2010 Share October 24, 2010 How to test mA? Or mAhr? Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 24, 2010 Share October 24, 2010 I've a few old Eneloop in my drawers, wanted to use a multimeter to measures their capacity in mA. According to some forums, using multimeter to test the batteries can cause the eneloop to burn, is that true?? leaving the multimeter on ammeter mode to measure current is essentially shorting the batteries. I am saying this from the POV that for an ammeter to do its job of measuring current flux properly, it has to have near zero resistance. (recall, ideally, ammeter has zero resistance) Link to post Share on other sites More sharing options...
English5b Neutral Newbie October 24, 2010 Share October 24, 2010 For battery alone you can only test voltage (V). Link to post Share on other sites More sharing options...
Boyboy 1st Gear October 24, 2010 Share October 24, 2010 u have to use battery analyser. those work by charging the battery til it's full, then discharge and measure how much charge the battery has held. i'm using a maha wizardOne analyser. can buy from east gear. one word of caution, maha imedion batteries suck. i heard better reviews for eneloop. generally i think sanyo rechargeables are the best, followed by sony. avoid the maha imedion batteries, but can consider the battery analyser. i used it to determine which batteries to throw away. supposedly it can also condition your batteries but i'm doubtful as to how well that turned out, since my imedions deteriorate quite fast even under rather light usage. maybe cos i always drain the battery fully Link to post Share on other sites More sharing options...
Billcoke 2nd Gear October 24, 2010 Author Share October 24, 2010 leaving the multimeter on ammeter mode to measure current is essentially shorting the batteries. I am saying this from the POV that for an ammeter to do its job of measuring current flux properly, it has to have near zero resistance. (recall, ideally, ammeter has zero resistance) Bro, thanks all for the feedback. Will be careful w the battery and not to short circuit them. ↡ Advertisement Link to post Share on other sites More sharing options...
Singpost courier dishonesty with incredibly lousy service
2019/2020 MCF Revamp - Feedback/Errors
