Roverboy 1st Gear November 14, 2010 Share November 14, 2010 any1 know how to solve this problem?got this message on my laptop.... ↡ Advertisement Link to post Share on other sites More sharing options...
Chewbacca 1st Gear November 14, 2010 Share November 14, 2010 CMOS battery? Link to post Share on other sites More sharing options...
Roverboy 1st Gear November 14, 2010 Author Share November 14, 2010 Normal battery Link to post Share on other sites More sharing options...
Zac Neutral Newbie November 14, 2010 Share November 14, 2010 Means that your battery is not performing as well as brand new. Got this message on Mac Link to post Share on other sites More sharing options...
Kac 4th Gear November 15, 2010 Share November 15, 2010 May I refer you to this thread in the Microsoft Technet Forum, which I have been monitoring for a while: http://social.technet.microsoft.com/Forums...ae-da1dd11b8d1a Link to post Share on other sites More sharing options...
Hosch Neutral Newbie November 15, 2010 Share November 15, 2010 May I refer you to this thread in the Microsoft Technet Forum, which I have been monitoring for a while: http://social.technet.microsoft.com/Forums...ae-da1dd11b8d1a Thanks for the link to this really informative thread. Seems that there is some compatibility issue between Win 7 and older laptops which were not designed for Win 7. So let me try to summarize: 1. If you are using an older laptop that was pre-installed with Vista, XP, etc and upgraded to Win7, you might be having this problem. Check your laptop battery software for the design capacity, remaining capacity. If the numbers seem wrong, there probably are. Changing to a new battery may not help, as the laptop hardware and firmware needs to be compatible as well. 2. If you constantly leave your laptop plugged into AC with battery, on some laptops over time the built-in battery meter becomes inaccurate and it will repeatedly overcharge and greatly reduce the battery life. In this case your battery is toast. Changing to a new battery will most likely resolve your problem. 3. If your battery appears to be "damaged" by Win 7, and you're keen to explore, you can try to reset the monitoring circuitry by: - Unplug the AC and let it drain as far as possible (may need to disable the warnings, hibernation, etc) - Let the motherboard circuitry recharge the batt (do not boot the machine, or Win 7 will take over and end up with the same prob) - Install the original OS or use LiveCD to check the battery. Note: #2/#3 are purely my own opinion and I do not guarantee that they will work or resolve the problem :) Link to post Share on other sites More sharing options...
Roverboy 1st Gear November 17, 2010 Author Share November 17, 2010 btw guys how do i restore to factory settings? the laptop comes with vista but i upgrade to window 7 ↡ Advertisement Link to post Share on other sites More sharing options...
Another MU Place To Consider
My EV journey to the i4
Battery for Honda Vezel
