Kilatz 1st Gear April 2, 2011 Share April 2, 2011 Any bros know what are the signs to look for when you need to change the spark plugs? Read that its between 40k to 80k depending on the type of plugs that you use. Since the day I bought my car, i have driven nearly 40k without any problem from my engine. But one day just happen to talk about spark plugs with my friends hence the question of "when to change"? Any inputs or advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Aeromania 1st Gear April 2, 2011 Share April 2, 2011 30k km Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged April 2, 2011 Share April 2, 2011 (edited) refer to your owner manual, different car have different requirement. usually changed at 40K but if you re-gap and clean it up... it could be use till ur COE expire... Edited April 2, 2011 by Tigershark1976 Link to post Share on other sites More sharing options...
Timex1441 1st Gear April 2, 2011 Share April 2, 2011 in the older cars, mechanics can take out n inspect the spark plugs to judge if need to change....not sure abt the newer cars....maybe they juz go by the km travelled n change as per manufacturers manual. Link to post Share on other sites More sharing options...
Csnewbie 1st Gear April 2, 2011 Share April 2, 2011 spark plugs changing relates to nos of times you start engines i think. when hard to start is time to service/change? Link to post Share on other sites More sharing options...
Mrbytez Neutral Newbie April 3, 2011 Share April 3, 2011 I just did a change for mine at 45k... Link to post Share on other sites More sharing options...
Sbtyong 1st Gear April 3, 2011 Share April 3, 2011 Spark Plugs are relatively cheap, just change yearly. Link to post Share on other sites More sharing options...
Breadandwater April 3, 2011 Share April 3, 2011 Spark Plugs are relatively cheap, just change yearly. This is true but entirely unnecessary. Some spark plugs can last 100k km or more. Link to post Share on other sites More sharing options...
Kilatz 1st Gear April 4, 2011 Author Share April 4, 2011 Just changed my plugs. Used KR16 orig Toyota parts. Costs me 25 dollars for everything plus labour.... but that is special prie for me :) checked at Autobacs they charge 35 dollars. I use normal plugs.... I prefer to use till 30 to 40k km and then change new ones rather than use iridium plugs. It's not too expensive anyway and I dont drive aggressively. Thanks for the inputs. By the way, my mech inspected my plugs and says it's still good to use for 10 to 15k km more but I already made up my mind to change hahaha. Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear April 4, 2011 Share April 4, 2011 wow.. I never change since the day I bought my plug til the day I sold my car haha!! Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear April 4, 2011 Share April 4, 2011 wow.. I never change since the day I bought my car til the day I sold it haha!! Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear April 4, 2011 Share April 4, 2011 refer to your owner manual, different car have different requirement. usually changed at 40K but if you re-gap and clean it up... it could be use till ur COE expire... +1 agreed! Link to post Share on other sites More sharing options...
BoyBoyBalls Neutral Newbie April 4, 2011 Share April 4, 2011 i just changed a new pair of brisks after 5000-6000 km... the old ones failed on me and started misfiring but the power is good ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
Changing of Spark Plugs
X for twitter change request
