Keithhiap 1st Gear September 26, 2011 Share September 26, 2011 Hi all, As subject, would like to have custom make spring for my coilover. Thanks Regards Keith ↡ Advertisement Link to post Share on other sites More sharing options...
Satria_neo Clutched September 27, 2011 Share September 27, 2011 None. Cause you will not want it. Manufacturers offer springs of different stiffness already. Link to post Share on other sites More sharing options...
Yuan 6th Gear September 27, 2011 Share September 27, 2011 Hi all, As subject, would like to have custom make spring for my coilover. Thanks Regards Keith They come as a set. I doubt there is any. Link to post Share on other sites More sharing options...
Maka Neutral Newbie September 27, 2011 Share September 27, 2011 Hi all, As subject, would like to have custom make spring for my coilover. Thanks Regards Keith You dun need to trouble yourselves with that la.. TEIN provides a range of springs to cater to all cars. If you like it super stiff, get the black spring stiffeners. If you want more stiff?? Add a rubber hose to your spring before fitting. Link to post Share on other sites More sharing options...
Satria_neo Clutched September 27, 2011 Share September 27, 2011 Btw, if you make your suspension extremely stiff, you may be to reinforce your suspension mounts. Link to post Share on other sites More sharing options...
5936 1st Gear September 27, 2011 Share September 27, 2011 I can only say to go to spring workshop. Look at Yellow pages. Some of this smaller size factories may still be around. Many years ago I custom made some tension springs for front seats. To replace the original softer springs. Its at one of the industrial park at Bukit Batok 2 or 3 floor, Sorry, cant confirm if they are still there. Problem is that you have to bring one spring for him to fabricate. I can do without one spring for seat, but can you drive with one remaining spring? Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear September 27, 2011 Share September 27, 2011 yeah. not worth customising CO. just search for the best fit and the most suitable one will do good. btw, take note that CO will improve handling especially cornering but will also lessen on the driving comfort. Link to post Share on other sites More sharing options...
Yc86 Clutched September 28, 2011 Share September 28, 2011 You have calculated your required spring rate alr? Are the damping rates 'matched' to your desired rates? The springs for coilover application is not any chapalang spring steel.. also need to be treated for corrosion protection and whatnot. Wonder if the spring shops in sg have the ability and capacity to make springs to that kind of quality and specifications.. =/ Link to post Share on other sites More sharing options...
Mrbalaku Neutral Newbie October 3, 2011 Share October 3, 2011 not sure if this is the one I saw at http://www.autoparts.vacau.com/ Link to post Share on other sites More sharing options...
Huffy Neutral Newbie October 9, 2011 Share October 9, 2011 what kinda springs u looking for? i know j**p chee sells straight springs.. u need to know ur Internal diameter/Length/and hardness .. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
Anyone try Cathay Pacific before?
New Zealand - anyone?
How do you know you are in midlife crisis?
