7seater Clutched May 30, 2013 Share May 30, 2013 Hi. I am facing some problem with my car air conditioning. The compressor during car starting has sound. tick tick tick for a while and gone. On normal drive or slow it is cold. Once I rev it hard or at high speed, the air cond no longer cold. Just fan is working. Any bros ever encounter such problem? Ever tried putting in a can of lubricant in Jan month into the system and becomes normal working well. But after a few days, it comes back to the same problem. Your advise is much appreciated. Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 30, 2013 Share May 30, 2013 check whether is your aircon pressure switch faulty anot? any also how old is your car already? probably might also due to compressor ageing and coming to fault soon. Link to post Share on other sites More sharing options...
Vicsaw Clutched May 30, 2013 Share May 30, 2013 Is it a Honda Stream? Link to post Share on other sites More sharing options...
7seater Clutched May 30, 2013 Author Share May 30, 2013 (edited) It is Mazda 2SP. Register 2007. Where is the air cond pressure switch that I can check on it? Edited May 30, 2013 by 7seater Link to post Share on other sites More sharing options...
SimplyTWL 1st Gear May 30, 2013 Share May 30, 2013 Maybe might be the aircon relay gone? Get it checked at workshop soon! Link to post Share on other sites More sharing options...
7seater Clutched May 30, 2013 Author Share May 30, 2013 Thanks. If relay is small damage. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 30, 2013 Share May 30, 2013 Thanks. If relay is small damage. My car last time same problem. I went markcool see ah huat. He say compressor going to spoil. Dunno can last how long. I changed a new compressor. Link to post Share on other sites More sharing options...
Bobby_tan 1st Gear May 30, 2013 Share May 30, 2013 Hi. I am facing some problem with my car air conditioning. The compressor during car starting has sound. tick tick tick for a while and gone. On normal drive or slow it is cold. Once I rev it hard or at high speed, the air cond no longer cold. Just fan is working. Any bros ever encounter such problem? Ever tried putting in a can of lubricant in Jan month into the system and becomes normal working well. But after a few days, it comes back to the same problem. Your advise is much appreciated. Thank you. Time for some aircon svcing my friend. Link to post Share on other sites More sharing options...
7seater Clutched May 30, 2013 Author Share May 30, 2013 My car last time same problem. I went markcool see ah huat. He say compressor going to spoil. Dunno can last how long. I changed a new compressor. If compressor jialat damage. Link to post Share on other sites More sharing options...
7seater Clutched May 30, 2013 Author Share May 30, 2013 Time for some aircon svcing my friend. Maybe. if it is able to solve the current problem, then OK. Just worry all trial and error. Always ask to change this and that. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 30, 2013 Share May 30, 2013 If compressor jialat damage. If only a few yrs to scrap....just drive till compressor spoil then try to get a 2nd hand cheap compressor. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear May 30, 2013 Share May 30, 2013 Mostly the tik tik tik sound is the magnetic coil In Sg, they change entire compressor In jb, they service the magnetic coil That's it Link to post Share on other sites More sharing options...
Eddiechang Neutral Newbie May 30, 2013 Share May 30, 2013 The only one that can help u now is the repairman. GL brudder... Link to post Share on other sites More sharing options...
7seater Clutched May 31, 2013 Author Share May 31, 2013 Mostly the tik tik tik sound is the magnetic coil In Sg, they change entire compressor In jb, they service the magnetic coil That's it So it is better to try service in JB? Do you have any recommendations with address? Link to post Share on other sites More sharing options...
7seater Clutched May 31, 2013 Author Share May 31, 2013 Calling GL brother? Need your help and advise!!! Link to post Share on other sites More sharing options...
7seater Clutched May 31, 2013 Author Share May 31, 2013 If only a few yrs to scrap....just drive till compressor spoil then try to get a 2nd hand cheap compressor. this is cheapest remedy. ni choice. weather very hot leh Link to post Share on other sites More sharing options...
13177 Hypersonic May 31, 2013 Share May 31, 2013 Usually compressor will spoilt when the car left 1-2 year to scrap. I have 2 friends, their compressor spoilt on 9th year. Link to post Share on other sites More sharing options...
Absu Neutral Newbie June 5, 2013 Share June 5, 2013 I am not sure what you are driving but on my previous ride (legacy gt), when I floor it, the compressor is programmed to be cut off by the ECU. So I often get a lot of compressor clutch dust because I floor it a lot and the clutch engage and disengage every time I do that. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
Singapore Problem Gambling
