KIA K3 Owners check-in!
TTT
So for interior lights, there are the flat panel type with different number of LED, e.g. 4,6,9 etc.
There is also the 'bulb' type which is LED also.. but bulb type can be used for exterior number plate, think this flat panel type cannot.
Not sure if bulb type is less bright..
but price difference for philips really a lot.
So bro 6888, 2 front 1 rear already charged $55.
2 front 1 rear, 1 boot about $80 is normal..
Only the philips give 12 years warranty... will never have to change again.. but maybe cheapo china LED also dun spoil that easily.
price is ok for me, although bro ricleosg sure got better lobang!
mine is flat type, simple & cheap is good, won't so easy spoil one lah.
mine is white, front should go for 6 led, cabin 9 is ok else too bright when all light up when open door.
Stock cabin bulbs are halogen bro...
Halogen is a gas discharge mainly used for headlights to produce high lumens. Another upgrade is Xenon gas discharge which is also called HID (high indensity discharge). Cabin lights are incandescent bulbs bro.
haha i not really into electronics... my bad... halogen n tungsten/incandescent bulbs all seem sama to me with a filament and produces yellow lights.
for interior i think white light at a comfortable brightness is the most practical. the stock cabin bulbs are generally too dim. One of the first things i change in my ride.
Ok. Must be real heavy.
Anyway all 3 reserved.
1 for the hairy bro and 2 for coolbluepica.
Thanks bro Raylimus for the boot springs. It really worked great. The spring up speed not too fast, looked like electric tail gate.
Can show video or not? What I don't like is when it reaches the top and the boot goes back and forth.
Same. Can take a picture of how you guys secure the 'key-ring' part to the boot area? I feel that it is not very secure le. Like will drop down.
Here
Here
Here
Pai seh dunno how to attach video.
You put your spring too tight. Need to extend the rod to loosen it.
Need to shorten the rod to make it tighter
trim.B4E7A014-14E8-4E50-ADA2-0742A2CC8D22.MOV
Here
Thanks bro for the video. Looks good...will adjust mine like yours.
You able to view the video? Funny I can't view my own video.
Can, I can view your video. Try using VLC player...my built in windows 10 player can too.
Just share a mod. I replaced the stock battery to varta silver AGM. car had obvious gain of power and torque.
Seriously? Changing of Battery can gain Power and Torque? I thought the battery is there as stored energy to crank the starter to start the engine? After that, the Alternator will take over for all the electricity the car needs...
Alternator connects to battery and battery out to accessories. It's connected in series not parallel. Battery act as a capacitor to temporary stores current and stabilises voltage as output from alternator varies.
When a bad battery is in place , it strains the alternator to keep charging it , alternator will off load earlier if charging a good battery, hence reduces engine load.
Output voltage from battery is high, = lower amperes.
Output voltage Low from bad battery = high amperes = electronics will not function correctly.
Good voltage resulting in correct reading perimeters by ECU , better spark , louder audio, brighter headlights, colder aircon etc.
