Sign in to follow this
Opel17
How to install Clarion MAX676VD
Received this set yesterday. Realized that it cannot be directly fit onto my vehicle Fiat Panorama.
I would like to seek advices/suggestions how to get the Clarion set installed on my Panorama.
Also received a reverse camera yesterday. Can this camera be able to connect to the Clarion unit ?
Hope it would not be very expensive [below S$100 ??] to get the Clarion and reverse cam installed.
Thanks in advance for advices/suggestions.
Share this post
how could you have gotten the set unless you've done your research? the clarion headunit is double din. your fiat houses a single din headunit.
Share this post
I got this set from a contest. Had mistakenly assumed this can be easily installed on my ride, before submitting my entry.
Edited by Opel17
Share this post
think you might need to chop your dashboard and custom a housing for the Clarion (provided you die die want install)..
Customised housing got no market rate... installation of Headunit alone can cost between $30 to $50 depending on which shop you go..
I modified the top dashboard compartment abit and customised a bracket for the Pioneer HU, below with green lighting is Stock factory built-in HU..
Share this post
Thanks for your information.
In my case, the installation is likely to be complicated and costly.
I may have to shelve the idea of installing the Clarion unit.
Share this post
