Reset ECU and HVS
Throttleb
for a moment i thought after removing batt -ve, the hvs -ve will do some work by being left there.......so that's why i was kinda confused
so that means need not leave the -ve hvs there lah.....most important is to remove the -ve batt? any experts can confirm?
there's usually 2 clamps to the battery posts, the positive and the negative. the positive can be distinguished by a red rubber cap over the clamp.
just disconnect cable from either terminal, as long as circuit is broken, electrical supply is removed. remember to off engine first, else unplug both also no.
(+) for red, (-) for black. If you plan to do a reset, just remove all connecting points to the negative terminal of your battery, leave it out for 5 to 20 mins taking care not to touch the loose piece on any metal bodies. Connect it back after that, your ecu have been reset. Applies only to vehicles that can do a ECU reset by breaking the circuit, by removing the connection to the battery.
Curious though.. earlier posts say to leave the -ve of HVS on the battery when resetting.. or is it like you said remove everything from the -ve of battery? confused.gif
No harm from removing everything. The only hassle is to reset your radio channels and clock. No harm to remove even the HVS. Just make sure you dun short anything.
http://www.tmo.com/theory/myth/ecureset.htm
Just wondering if there are real benefits in doing this? Was doing a search on the Net on this, some say useful, some say no use. unsure.gif The above article says resetting the ECU also remove any trouble-codes stored inside. In my car, removing the -ve terminal also resets the trip meter.
In any case, the ECU is suppose to re-learn the new engine characteristics immediately with new mods put in right, since it it constantly monitoring all the various sensors? So it sounds like resetting ECU is only for the impatient people? sly.gif
IMHO not all ECU are learning type.
so even if u reset, maynot do anything.
i neber reset my ECU yet after HVS or for any other suff, but i notice the the adjustment kick in a day or two later. not only for HVS...
You are probably right abt the impatient people.. [nod]
I resset to ensure that whatver magnets /etc that are dumped in are recognised by the sensors.
For my last car, I know for sure that it learns the throttle and shift charcteristics
of the last driver in 10 increemental steps.
I just cannot wait to let it drive 4-500km before it learns my style.
