Zrun Neutral Newbie October 3, 2003 Share October 3, 2003 Just installed my foglights, and tested everything to be working. However, right now, the whole foglight is on entirely different circuit. How to set it up such that it'll not light up if my light is not turned on? Need to splice wires? Also, how to get a wire thru the firewall?? No holes for me to pass thru! There's a hole, but it is already filled with wires. Drill? ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear October 19, 2003 Share October 19, 2003 Think u got to connect it to a separate switch... can anyone confirm? Link to post Share on other sites More sharing options...
Zrun Neutral Newbie October 19, 2003 Author Share October 19, 2003 I went to audio shop and ask.. They say I need to use a relay.. Because if I tap current from headlamps, the fuse might blow easily Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 19, 2003 Share October 19, 2003 (edited) Hi there Zrun Pls remove the current tapping from your lights. When you blow your fuse, you might burn some wires as well. Try this: http://www.carcentral.net/content/guides/H...iary_Lights.php For connection 85 and 86, splice your driving light wires and join them here. But if you go hi beam, your fogs will go off. Actually no harm having your fogs on a different circuit. But maybe have it connected to your ignition. Once key is removed, all lights will go off. I think it's a better idea. Hope this is helpful. Edited October 19, 2003 by Lester Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie October 19, 2003 Share October 19, 2003 http://www.rssingapore.com/cgi-bin/bv/sear...rchText=531-352 These connectors maybe useful... Link to post Share on other sites More sharing options...
Lester Neutral Newbie October 19, 2003 Share October 19, 2003 Hi there Mmythos See that you are a RS user as well? I go to theri head office in tuas to buy stuff often. For Zrun, as he is in US. He's able to get stuff from plcs like RadioShack. Thanks for the input! ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Citroen C4 1.2 Sensor & Display
