Max1218 1st Gear November 6, 2003 Share November 6, 2003 hey bro, where did u fix up the SP???? ↡ Advertisement Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 (edited) why? backside itchy again isnt 4doors with dynamat extreme (outer layer) - 55 Auto $220/- 2doors with accumat - sin kit $120/- boot with some thick carpet material - sin kit $80/- done with dynamat first and the SQ really improves even using stock sound system. even CO commented Edited November 6, 2003 by Sinifm Link to post Share on other sites More sharing options...
Max1218 1st Gear November 6, 2003 Share November 6, 2003 bro, why did you add the dynamat on top the accumat???? insufficient SP??? Link to post Share on other sites More sharing options...
Waipor Neutral Newbie November 6, 2003 Share November 6, 2003 hehe.. this type of question need to ask one? butler audio? they have some new models out check them out http://www.butleraudio.com/specs.html . soundstream also not too bad else audiobahn http://www.millionbuy.com/soudavinci.html Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 go to slt 2nd floor edison n get lazar 4 ch amp 700 watt at only 270 thanks for the suggestion...btw, how much does installer charge for installing the amp? Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie November 6, 2003 Share November 6, 2003 go to slt 2nd floor edison n get lazar 4 ch amp 700 watt at only 270 270 for 700 watt... 4 channel.. ermm watz the rating per channel....im looking for a budget 4 ch amp too.... getting some second hand speakers to drive it... u got the amp? Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 not on top...the door has 2 diff layer of frame body. there is a gap of abt ~5cm between the 2 frame. that why 2 layer of SP will improve SQ by filtering off exterior noise and reduce any body vibration....blah..blah...really worth it as for the boot, just listen to the rear during wet days and after SP the boot, only reduce minimal noise. quite disappointed. Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie November 6, 2003 Share November 6, 2003 u got to depend on wat kind of cable they use... where to mount it.. need to build a rack for it anot... need to rewire the whole car anoot.. got quote 80 bucks for installation plus cables.. duno wat cable also.. thatz a rough price... Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 hmm...ok. at least know the market rate btw, one installer actually recommend amp be installed under the passenger seat. any pros/cons? Link to post Share on other sites More sharing options...
Max1218 1st Gear November 6, 2003 Share November 6, 2003 why? backside itchy again isnt no la.....ears itchy..... 4doors with dynamat extreme (outer layer) - 55 Auto $220/- where is 55 Auto??? r they the best price in town??? 2doors with accumat - sin kit $120/- why only 2 doors....front or back???? boot with some thick carpet material - sin kit $80/- where material is it??? done with dynamat first and the SQ really improves even using stock sound system. even CO commented sure bo??? I was quoted for the whole car, 1 layer of accumat for 325 Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie November 6, 2003 Share November 6, 2003 need any help in the engine and handling dept.... sure sure.... anything will be appreciated, newbie to the car Link to post Share on other sites More sharing options...
Max1218 1st Gear November 6, 2003 Share November 6, 2003 not on top...the door has 2 diff layer of frame body. there is a gap of abt ~5cm between the 2 frame. that why 2 layer of SP will improve SQ by filtering off exterior noise and reduce any body vibration....blah..blah...really worth it wow, so cheem..... hmmm, if like this, which one should do first??? Link to post Share on other sites More sharing options...
Alan22 Neutral Newbie November 6, 2003 Share November 6, 2003 ermm for cars.. all usually install under the seat or boot...under the seat i think u wont be able to admire ur pretty amp..and if anyting were to cxxk up.. u got to remove ur seat also...(depending on which part under u install) installing in the boot needs to built a rack to hold the amp.. or u can mount it at the side..cleaner look.. got not much experience with frens who haf amp under their seat..amp is giving out heat when u on it.. so under the seat might provide warmness for ur butt... ehhhe most of my frens got it behind their boot.. neatly installed at the side or rear.. juz my opinion.. need somemore advise from expert here.. im jz a newbie too.. Link to post Share on other sites More sharing options...
User12343 Clutched November 6, 2003 Share November 6, 2003 I beg to differ. so long as the amps are not driven into severe clipping, it's unlikely to damage speakers. ok, will do a weekend window shopping just wanna clarify, if the speaker spec is 80W. the amp should have >80W RMS to power the speaker ? That serves as a guide. Generally speakers get damamged with overdriving underpowered amps. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie November 6, 2003 Share November 6, 2003 hehe.. this type of question need to ask one? butler audio? they have some new models out check them out http://www.butleraudio.com/specs.html . soundstream also not too bad else audiobahn http://www.millionbuy.com/soudavinci.html Looking at millionbuy, any direct/indirect experiences with them? Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 55 Auto addr is, blk2 bukit batok st 24, #02-08 SkyTech. they charge $60 per piece with installation. and i bring it down to $55/-. trust me lar, it really filter exterior noise out. thus better SQ. closing the door also got this solid sound/feeling. whole car ? 4 doors, floor plan ? any other place ? Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie November 6, 2003 Share November 6, 2003 (edited) precisely, stop when you smell smoke and keep the fire extinguisher handy read again, "speakers get damaged with overdriving underpowered amps." Edited November 6, 2003 by Redliner_sg Link to post Share on other sites More sharing options...
Sinifm Neutral Newbie November 6, 2003 Author Share November 6, 2003 dynamat is thicker than accumat. i would think dynamat is better at the outer layer. u can even go 2 layer of dynamat ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommendation for ear digging?
Any recommendation for good facilities Health Centre/ Spa
Recommendation for private driving instructor near BBDC
Recommendation for Spectacles
Recommendation for gynaecologist
Any recommendation for Malaysia Data Plan
Audio Shop Recommendation
