Saaber Neutral Newbie November 9, 2003 Share November 9, 2003 You are welcome... ↡ Advertisement Link to post Share on other sites More sharing options...
Mash4077 Neutral Newbie November 11, 2003 Share November 11, 2003 Hi. It's not a DIY job. Must take out the header to be cleaned, and the ceramic coating applied. Had it done at Alfa City at Sin Ming. Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie November 11, 2003 Share November 11, 2003 Try Thermotec to wrap. Im using that. The reduction is heat is substantial in feeling. Powerwise, I hardly even noticed. In another car that was ceramic coated, the heat was still present so we had it theromotecced on top of that. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 12, 2003 Author Share November 12, 2003 Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 12, 2003 Author Share November 12, 2003 Hhmmm wonder if there will be any improvement in performance. Met another AROC member at MASSA and he had his wrapped in JB. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie November 12, 2003 Share November 12, 2003 you will feel the effect if you do prolonged hard run..... Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 12, 2003 Author Share November 12, 2003 Are you considering the themal wrap as well? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie November 12, 2003 Share November 12, 2003 (edited) done it the first day I collected the car... anyway, the thermal wrapping have been around for a long time...I have done it for my past 2 cars also ... Edited November 13, 2003 by Saaber Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie November 13, 2003 Share November 13, 2003 very minimal in many cases.. at most it should be like driving at night when you drive on hot day. My take is NOT to wrap all the way but just up to down pipe becos u need it flow by heat transfer from hot to cold so gases will flow faster... if u wrap all the way to CAT, its HOT all the way. The CAT is usually hottest part of exhaust system.. U using the same nick in AROC? Link to post Share on other sites More sharing options...
Chayyh Neutral Newbie November 13, 2003 Share November 13, 2003 sorry hor bro..ask stupid question.. i tot gas flow is from cold to hot..dense to less dense.. might be wrong. but that's not my main question. where to get this themal wrap har? Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie November 13, 2003 Share November 13, 2003 the area that is wrapped will be hotter inside. u are actually containinh heat inside the exhaust. therfore ...hot air inside the headers flows faster than cold so will be expelled faster Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 13, 2003 Author Share November 13, 2003 wah lau... got this type of tweak and neber share share one huh? Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 13, 2003 Author Share November 13, 2003 Point noted. Will be getting Peter from Alfa City to do it for me. Almost the same nick. Have you decided on the Euro-R yet? Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 13, 2003 Share November 13, 2003 I think I'll also do mine, after the ops on the rear first Link to post Share on other sites More sharing options...
Saaber Neutral Newbie November 13, 2003 Share November 13, 2003 you never ask earlier mah... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie November 13, 2003 Share November 13, 2003 I see... Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie November 13, 2003 Share November 13, 2003 (edited) why not u consider heat shielding ur intake or airbox to have the 'CAI' effect? http://forum.e46fanatics.com/showthread.ph...=coldair+intake Edited November 13, 2003 by Mmythos Link to post Share on other sites More sharing options...
Vtim 3rd Gear November 14, 2003 Share November 14, 2003 the header is very short & it arrange the same way as the Stream, the header doesn't goes underneath the engine ↡ Advertisement Link to post Share on other sites More sharing options...
Car Wrap or respraying of the car?
Sealant or coating for vinyl wrap?
Dashboard wrap
Dashboard wrap
How to deter car thieves from aiming ur car
DIY steering wheel wrap - very nicely done !
Car window pillar (frame) wrap
Which is better? Car Wrap or Spray Painting?
Heat insulation wrap for DIY. Looking for suggestions
