Need to replace clutch???
Superseven
Thanks both for you for the insight. I just bought the presea after 1 test drive and had drove for 2 week with the problem getting from manageable to a disaster.
To think the dealer had the cheek to tell me I cannot accerate too hard becos its a heavy duty clutch.
So since the dealer does repair, I don't think I want to deal with this dishonest merchant anymore because he also assured me I'll pass my car inspection but I failed the solar film and headlights when I sent to inspection center 2 days later. Wanted to charge me to ensure my inspection will go through whe I reflected the issue. In the end, lost my trust and I rather look for a solution on my own.
Didn't expect a repair job so soon but since my its my failure to do my proper checks, don't want to think about too much except to get the car road worthly and maybe drive another max 1-2 yrs. If that's the case, would there be a change in advice for me? I had asked whether I can change to a used clutch but workshop ask me to change new so I didnt know whether its better for me or maybe its difficult for them to look for used clutch as well.
Thanks once again for all the helpful bros here. CHEERS to your weekend!!
presea club? The one on delphi forum? The dealer is at that forum posting ads here and there but I shall not name names on public forum...
yeah delphi forum. There are a couple of very very good bros there, like nisyoko and xiong22.
nisyoko surf mycarforum too, but seldom see him post.
Edited by Turbine
Thanks bros! Got my problem solved and saw gearbox was also patched up below when car was raised so hopefully won't have more troubles ahead for the short term.
Damage as below :
Clutch Pressure Plate $75
Clutch Lining $58
Clutch Bearing $30
Gear oil 3 litres $15
Labour $150
Total after GST - $344
Found another recommended workshop with better quote
hi bro
the presea forum is at
http://forums.delphiforums.com/presea/start
but in the past few months, we have not been too active
there are a number of bro who had either sold or scrap
their rides
also, there are new owners like yourself too.
good to hear your problem is rectified and with some
tuning of the engine, and TLC i would think your ride
will serve you more then the 1-2 years u are thinking
of.
cheers [:)]
Hi,
For my old Presea, I had to change my clutch every 18 months or so... something about the way I drive sly.gif
Anyway, my mechanic charges about S$250, inclusive of labour.
Once, I even changed my gearbox to a recon-Japanese (felt like brand new)... cost me S$500 for gearbox + clutch assembly + incidentals + labour!
If you need a contact, do let me know.
$250 is cheap for all the work judging from what we've seen so far but you change the clutch because of regular good maintainance practice or do your wear them out in 18 months? I had drive a citreon berlingo before this and the van lasted 3 years with only a timing belt change and nothing else really.
Anyway, ow does a new gearbox feels like? Maybe u can pass me you contact mechanic too.
The presea forum is really "small cats on or two", probably after all not many on the road already. Or nissan drivers not really forum pple?
After clutch change from wear out racing clutch to normal clutch. Left leg not so siong and feels quite comfy driving 80-90km/h most of the time.
Used to drive 100-110km/h when driving my dad's sunny then when I switch to van, learned to appreciate driving within speed limit and enjoy the view.
90km/hr is at 2.8K rpm so is that normal? I feel the 1st 2 gears pick up so-so if I change gears at 2.5k rpm. If I do 2.5k rpm gear change on my van sure pick up faster so is it car need to change gear at 2.5k rpm? Last time sunny auto "change gear" at about 2.5-3k rpm if i remembered correct.
Hmm... we r OT liao... [laugh]
Huh? i last time change gear ever 2.5K, sometimes even 2.2-2.3k also don't feel really slow.
Able to keep up with traffic.
90km/h of that RPM is about rite.
100km/h at about 3000rpm.
i think u need your mech to tune your engine.
ask him to adjust the distributor to more advanced.
slightly it might now be at 'retard'.
hence the slow pickup.
cos i do change gear at 2.5 too, ok leh.
no worries lah... always OT one. [laugh]
anyway while driving, got wind noise?
mine still not solved after changing rubber.
goggled, and reckon need to adjust and align
the window.
yes, now we are officially OT.
[:p]
Maybe the pick up was alright after thinking that my previous ride is a 1.9 van so maybe feel more power at lower gears. It was really stable at 100kmh (2.8krpm)due to conti made heavy metal so probably not a fair comparision. Drove fiat uno years ago b4 it was scrap and couldn't monitor rpm as no taco and i ram it quite hard.
I think wind noise comes about >90kmh so if within speed limit still acceptable lor, I oso thought it's rubber but from your exp seem it's not. Experience some water coming in when going carwash kena spray by their jets too.
All in all, quite happy w her so far besides being a bit low so when filtering out sometimes block by car besides you and you can;t see traffic coming.
Was told engine oil last used was semi-syn but i was thinking switching to mineral. U think 5-40W is alright for her?
mine no water leakage from windows.
if water is indeed seeping thru, i think need to
replace rubber lining, then do the alignment
of the window panels.
yes, it takes some time to adjust to the low
setting of the car. but once u get used to it,
u will find going round corner is rather fun
with it.
[:p]
if the last oil is semi-syn, and there is no engine
oil leaking i would think u can continue to use it
for the next servicing.
slightly more exp, but can use it up to 10K mileage
if i'm not wrong. plus semi-syn is less 'thick' in
weight which you should feel more responsiveness
from the car.
i'm using mineral 5-40W mineral myself now but in the
next servicing or the one after that i will be using
semi-syn too.
upon which i hope there's less time to be spent with my
mech, and more time else where!
[laugh]
You need to slot in the gears properly, not like my previously well-worn gearbox, where I could simply knock it in from almost any angle.... perhaps that's why my synchromesh at the first gear wore out..... tongue.gif
My mech's contact: will PM to you
