Cool_jazz Neutral Newbie November 29, 2003 Share November 29, 2003 (edited) Hey guys My car's selespeed will automatically blip the throttle when I down shift. So I am curious about how its done in a manual car. How do you do that in a manual car? Do you always blip your throttle when you downshift? Is it difficult to get it right? Cheers Cool_jazz Edited November 29, 2003 by Cool_jazz ↡ Advertisement Link to post Share on other sites More sharing options...
Assassin Clutched November 29, 2003 Share November 29, 2003 Not sure about the rest. But to blip throttle while downshifting..I would do this: - step on accelerator pedal at a constant level and do not release - while doing that, clutch in and downshift, this should blip the throttle as you are downshifting Hope I'm doing this right. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 29, 2003 Author Share November 29, 2003 erh won't that spoil your gears and give you a massive jerk? I think blipping the throttle is to reduce "engine brake".... correct me if I am wrong. Link to post Share on other sites More sharing options...
Seansene 1st Gear November 29, 2003 Share November 29, 2003 From the little I know, it would match speed (not engine speed) by increasing the revvs of the lower gear. I guess most people seldom need to do that except when pressing hard at a corner... Link to post Share on other sites More sharing options...
Assassin Clutched November 29, 2003 Share November 29, 2003 Nope, it wont give you a massive jerk...I've done it before..well..used to anyway. Main thing is not to step too much on the accelerator...but just enough to blip the rpm to the required level and keep the engine boiling in its optimum torque band. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 29, 2003 Author Share November 29, 2003 Hhmm good explanation. Have been taught by my ex-instructor to lift off when changing gears... Link to post Share on other sites More sharing options...
Seansene 1st Gear November 29, 2003 Share November 29, 2003 That's the ah pek way of driving Soya, where are you?? Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 29, 2003 Author Share November 29, 2003 that was what I was taught. What did your instructor teach you? Link to post Share on other sites More sharing options...
Assassin Clutched November 29, 2003 Share November 29, 2003 Your instructor teaching you to save fuel mah. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 29, 2003 Author Share November 29, 2003 must be man... Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear November 29, 2003 Share November 29, 2003 (edited) Just give a light tap on the throttle just before you release the clutch after downshifting. Since manual cars do not have the luxury of the gearbox/ECU doing the rev-matching, it takes a little practise before you get the timing and blipping right. (I'm very inconsistent, sometimes swee swee, sometimes off, causing the car to jerk) If you are braking at the same time, then you have to use the toe-heel technique. Here's what I usually do, approach corner, brake, clutch-in, downshift, blip, declutch, release brake, throttle. Sometimes you have to do it so fast that the downshifting and blipping happens simultaneously. This has two advantages, smoother gear changes and you'll prolong the life of the synchromesh. I was told in the early days where cars with dog boxes (no synchromesh), you really have to blip and downshift at the same time to match the revs (match the road speed with the gear speed). I guess we modern drivers and spoiled by synchromeshed gearboxes My $0.02, hope the other more experienced forumers can share their techniques or correct any of my mistakes Edited November 29, 2003 by Slowpoke Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 29, 2003 Author Share November 29, 2003 Thanks bro... beginning to understand things a little better now... Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear November 30, 2003 Share November 30, 2003 Not sure about the rest. But to blip throttle while downshifting..I would do this: - step on accelerator pedal at a constant level and do not release - while doing that, clutch in and downshift, this should blip the throttle as you are downshifting Hope I'm doing this right. Have you actually tried this method yourself? I tried it once when I just started driving. If you hold on to the throttle even if it a little when you clutch-in, you'll be bouncing the needle off the rev-limiter and causing a BIG jerk when you declutch. Maybe my right foot too heavy on the accelerator..... If I'm not wrong its called "Power Shifting" if you do it right, as in you match the revs with the gear speed and road speed. An amateur like me will never get it right Link to post Share on other sites More sharing options...
Mmythos Neutral Newbie November 30, 2003 Share November 30, 2003 "the toe-heel technique. Here's what I usually do, approach corner, brake, clutch-in, downshift, blip, declutch, release brake, throttle." er... i don suppose that is the correct 'toe and heel' method... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie November 30, 2003 Share November 30, 2003 Here's the article on heel and toe... http://www.mycarforum.com/forum/gforum.cgi?post=99680;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=unr ead#unread://http://www.mycarforum.com/forum/gfo...=unr ead#unread://http://www.mycarforum.com/forum/gfo...=unr ead#unread://http://www.mycarforum.com/forum/gfo...=unr ead#unread Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 30, 2003 Author Share November 30, 2003 Hi Saaber Based on the write up, seems like the driver is braking when doing the turn. Shouldn't it be brake and engage lower gear b4 the turn and power up at the exit? Thanks Link to post Share on other sites More sharing options...
Wrxblue 1st Gear November 30, 2003 Share November 30, 2003 no worries bro....its difficult to explain everything on paper... just come and join us for a track session someday and you will get to practice all the knowhow.... and definitely in a safer environemnt than our public roads.... Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie November 30, 2003 Author Share November 30, 2003 no manual car to try on leh.... ↡ Advertisement Link to post Share on other sites More sharing options...
DIY cleaning throttle body
Throttle body cleaning
DIY: Porting & Polishing a Throttle Body (Video Tutorial)
Throttle Body
Throttle Body
DTE pedalbox throttle controller
Throttle Controller
Throttle Controller
Any shops to buy throttle body cleaner?
Throttle position sensor for honda civic d15z7
