Yen9 Neutral Newbie August 7, 2002 Share August 7, 2002 Hello all, I need answers real quick...the radiator's pipe(the one closest to the engine) got a small tiny leak. How shall I go along with this? Everytime I feed water to the radiator, it leaks, droplets but it sprays when its hot ! I stay in Toa Payoh...any recommendations of repair shops? I like to cut short my driving time to any repair shop. thanks alot, yen9 ↡ Advertisement Link to post Share on other sites More sharing options...
Sky8807 1st Gear August 7, 2002 Share August 7, 2002 Hi, Look like a hairline crack, and when hot where it expand, water escape. You mention pipe, was wandering whether is it the rubber hose that connect the radiator and the engine, there are two actually. One on the top and the other on the bottom. Most petrol station with workshop facilities are able to fix this problem. Only problem is the hose itself for you car model. You can go to Lor 8 industrial area there are also workshop to repair the snag. If it is the rubber hoses, then I would suggest to changed both if possible, becos when one fail, the other is also ageing already. Don't know what car you are driving, some old car uses a blank to plug the hot water pipe to the passenger compartment, the plug can also crack with time. And it is wise to check that the cooling fan is working properly. Link to post Share on other sites More sharing options...
Yongwd 1st Gear August 8, 2002 Share August 8, 2002 i guess the water pipe has burst. Get it replaced asap. Are you talking about the top radiator hose that has burst? change the bottom one as well including the rear by-pass hose if any. there are workshops in Lor 8 near poly clinic Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie August 8, 2002 Share August 8, 2002 Try my mech at Blk 29 #01-215 Sin Ming Ind Est, Ah Lin. Get the hose replaced ASAP Link to post Share on other sites More sharing options...
Yen9 Neutral Newbie August 8, 2002 Author Share August 8, 2002 Thanks alot guys, will do asap. ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
How to clear kitchen choked floor piping?
Aftermarket turbo charge pipe
Radiator slight crack
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
Radiator tank leaks
Radiator tank leaks
Plastic weld
Plastic weld
