Technical terms
Acemundo
but still am i right to say turbo cars still have higher air intake than normal cars? but the ratio of fuel to air is higher?
also does carburettor cars have turbo?
Yes you are right that there is higher air intake...
Yeah I suppose before there was electronic fuel injection there were already turbos on carb engines...
You are welcome.
One the other note about relation between cam, cylinder, valves.... Cam pushes the valves to open and close them at the right time, to let the preset amount of air and fuel to go into the cylinder, and also to let the burnt mixture out to the exhaust.
Cam is timed (by timing belt) with the crank shaft. Crank shaft is driven by the pistons in the cylinder. Explosion of the air/fuel pushes the pistons downward, which then moves the crank shaft. Crank shaft is connected to the gear box and drives the gears and thus the wheels.
Bore is the diameter of the cylinder and stroke is the linear distance travelled by the piston between the lowest most position (Bottom Dead Centre) to the upper most position (Top Dead Centre). Design of the valves, placement of sparkplugs, engine capacity, and engine layout determine diameter and length. Theoretically, larger bore increases power.
Imagine a coke can.. the bore is the diameter the circular cross sectional area of the cylinder.. if you cut thru it with a horizontal plane. The stroke is the height of the cylinder..
Edited by Yttrium
so am i right to say more cams and valves are more effective and perhaps efficient? cos more variation of the number of valves opening in respect to the speed or torque. cos if say 1 big cam with 2 big valves (1 inlet, 1 outlet), its like using a big knife to slice a small chicken?
does cam and valves affect the speed and torque of the car? what abt cylinder? does it affect speed and torque?
what happens if there are a big bore with short stroke?
Yes, more cams and valves will be more efficient because the individual valve can be timed to open and close independently at the optimum timing. It can also be lifted with the optimum opening to allow correct amount of air/fuel to go in at certain rpm range. Theoretically, low rpm calls for lesser air/fuel and high rpm calls for full opening to give optimum power/torque with the best efficiency.
The power and torque of the car is determined by the amount of turbulence of the air/fuel mixture in the cylinder, and release the combusted air/fuel. To create increased turbulence, air/fuel must only enter the cylinder at the correct time with the correct amount. To create longer lasting turbulence, the design of the cylinder and piston will also play a major part. As such, yes, cams, valves, cylinder, piston, and crankshaft all play a part.
There will not be a big bore and short stroke. The ratio is governed by a fixed aspect ratio. Bigger gives more power but shorter stroke will not generate good amount of revolution to the crankshaft.
Carburetor cars can have turbos but there are big problems behind it.
Firstly, there are two kinds of turbo setups. Draw-through and blow through.
Draw-through turbos for carbureted engines means to have the turbo after the carburetor. Big problem. The fuel and air mixture that the carb does makes the air denser for the turbo. Turbo becomes hot. Very inefficient.
Blow-through is more efficient as the air is colder and not dense with fuel. But a new problem exists. Carburetors do not understand pressure. They mix the fuel with the air through a pressure drop.
It is hard to find turbos on carburetted cars. You can find superchargers but very little turbochargers in such cars. There are some oddities around like the Daihatsu G11R GTTi Charade. Most are driven beyond repair.
Edited by Genie47
so it does make sense to choose a car with more valves, cams and cylinders?
the only drawback is perhaps more of the above more prone to break down?
The principle of carburetion is based on the Venturi effect. The venturi principle is a restriction in a passage that will cause incoming air to increase its velocity, while pressure will be reduced. Reduction in pressure draws fuel into the air stream.
That is why the carburetor does not understand pressure. It understands "no pressure" [laugh]
The principle is simple and yet the carburetor is very complicated yet dependable.
Edited by Genie47
A law of engineering states that the more parts you have in a system, the more it will go wrong. [laugh]
The simplest designs usually win in reliability. Look at the old air-cooled VW Beetle.
EFI mixes the petrol in the combustion chamber. Many kinds of EFI.
TBI - Throttle body injection. Almost the same as carburetor. You have a "carburetor" with 1-2 fuel injectors. No float bowl or any complicated carburetor parts. Fuel is injected into the throttle body as it sucks in the air. Just like the carburetor, it has fuel distribution issues and limited by intake manifold design.
MPFI - Multi point fuel injection. What most cars are today. Fuel is injected just above the intake valve. No distribution issues.
DI - Direct injection. A little different from MPFI. I believe some Nissans are DI. System is similar to diesel engine's DI. Fuel is injected directly into the combustion chamber.
For more information, go to http://www.affordable-fuel-injection.com/
Now you know why turbochargers and superchargers mate well with EFI systems.
why would there be a difference between di and mpfi? unless of course u telling me the fuel just above the intake valve in mpfi scenario goes through another process before being burnt in the combustion chamber?
