VTI or TS
Beyond_26
actually es1 is only abt 4-5 k more ex than vti. i had thought of that too. how much u bought ur es1?
Hi Beyond_26,
Since you have narrowed your choices down to 2...best is to do a test drive yourself and see which one you prefer to drive...day in and day out. nod.gif
Between the 1.5 and the 1.6, the performance is different. The 1.6 has higher torque but lower hp. 0-100, the 1.5 takes 9.2 sec while the 1.6 takes 10.2 sec.
Other than that, the 1.5 uses electric power steering while the 1.6 reverts back to hydraulic power steering. Hydraulic one better........
The engine design is basically the same but I believe for the 1.6, they tune it down so as to reduce its emission level.
There could be more difference, but that's all I know. [;)]
i bought it 2nd hand at depeciation about 6.5K/yr. Its manual and the consumption is great. With normal driving can get better than 13km/l. Lots of reving also can get about 11.5-12km/l. But maybe because i'm on stock 15inch tires. Never really tried top speed but at ns highway, the accleration to 180 is faster than my expectation and have push to 200 on a flat road before. Still can go but then... on 195 tires dun have enuf guts to push further. Plus the engine already almost red line liao.... but by theoretical calculation, the car can reach about 215/218 before rev cut at 5th gear.
That's fast. 200km/h
In your opinion, what kind of driving style is most suitable for a VTI? ie. ppl who like to stay at the high, mid, low of the rpm? to fully make use of the 'sweet spot' of the engine.
In a TS, I find the sweet spot 3-5K rpm is best. for take off, a decent upshift between 4-5k is just nice to keep up with other cars.
At cruising , it there is not punch below 3k 5th gear. however, when reach 3.5k rpm, the pull is there to bring to 5k in seconds. (tested up north)
In SG roads, I don't to this >4k rpm at 5th gear (>130km/h), normally downshift to 4th to bring up speed if neccesary for overtaking.
As u said, I also not enough guts to test the limit.
well...honda normally play cheap by using very short gear. I'm already > 3K rpm in 5th gear from 95km/h onwards. Hence, most of the time on sg road just use 5th can overtake most car easily. Never really count how fast from 100-180 in 5th before though.
play cheap? Which model are u refering to?
I guess there is alway pros and cons on every design.
Having shorter gear means better torque at high-end?
6.5k/yr for es1 not bad huh, the fc oso quite good. not bad leh can reach 200+km/h, Too bad TS can only reach a max of 174km/h according to their website. If i go NS, sure ganna eaten up one. Unless change the whole engine to wrx one but not worth it.
For some reason, TS can go up to 190+. It'll take some stretch of road to reach the speed. according to other drivers who has done that.
IMHO, these is speed is good only if u are in a hurry. :-) and definately not a enjoyable ride for a 1.6L traveling at its max speed.
Actually in sg what it really matter is the pick up speed rather than the top right? Since u have driven a ts, how's the pick up, is it acceptable? Should be going to test drive next week.
ES8 = 1.5L SOHC Vtec, 115BHP & 139N/M
ES5 = 1.6L SOHC Vtec, 110BHP & 152N/M
sorry I forgot which RPM for the above figures but the 1.6L has a higher Torque & at a lower RPM compare to the 1.5L so makes it a better city driving then the 1.5L wink.gifwink.gifwink.gif
