Heavenkid Neutral Newbie July 24, 2004 Share July 24, 2004 hiyo bros... how long does it get a coilover to soften? as in not so f**king hard... cannot tahan the trembles jus after installing it... sota regret liao.. haha... ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 25, 2004 Share July 25, 2004 It doesn't.... Link to post Share on other sites More sharing options...
Heavenkid Neutral Newbie July 25, 2004 Author Share July 25, 2004 hai... then there is only one way out.. Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie July 25, 2004 Share July 25, 2004 The harder it is the more i like it! Link to post Share on other sites More sharing options...
Heavenkid Neutral Newbie July 25, 2004 Author Share July 25, 2004 u fierce man.. hehe.. some like some dont like... Link to post Share on other sites More sharing options...
Phochem Neutral Newbie July 25, 2004 Share July 25, 2004 ferry more adults ard.... tat might be a way.... full load.... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 27, 2004 Share July 27, 2004 What kind of coilover you are using ? If you are using adjustable ones, then you try to soften the rebound rate so that it will not be so harsh. Alternatively if you want to keep the coilover but still want a softer ride, check if your coilover has option to change the spring rates. The lower the rate is the softer the ride. Really cannot...see if someone willing to mod the coilover for you or not (but then again...this option is kinda stupid cos pay so much to use lesser...if you know what I mean) Take the shocks apart and drain out the oil then use less dense oil to refill. If still cannot, there is a valve inside that controls the rate of the rebound on the shocks....enlarge the valves so that it allows more flow hence the ride will be softer. Link to post Share on other sites More sharing options...
Mondeost220 Neutral Newbie July 27, 2004 Share July 27, 2004 u gt fleshy buttock isit? Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie July 27, 2004 Share July 27, 2004 haha nope, my butt is very hard one! Must get comfortable seats and rock hard suspension! Link to post Share on other sites More sharing options...
Heavenkid Neutral Newbie July 28, 2004 Author Share July 28, 2004 wah... u know so much about coilover ar.. even can drain the oil.. haha... too ma fan liao.. thanks anyway.. for yr suggestion.. ↡ Advertisement Link to post Share on other sites More sharing options...
MALAYSIA TIPS - Long Distance Driving Trips
New shock absorber not comfortable (Tokico)
Ultrasonic electronic mosquito repellent. does it work?
Does haze affect GPS signal?
BTO flat bathroom doors splitting, HDB does nothing
How long can engine oil be stored?
