Yansen Neutral Newbie August 5, 2004 Share August 5, 2004 hi all, just wondering if it is safe to use used wiper blades (which u have replaced with new ones) to wipe away the excess water after a car wash? will it scratch the paintwork? thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Dwoon 1st Gear August 5, 2004 Share August 5, 2004 First of all, don't see it being efficient (maybe only for the roof). Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 5, 2004 Author Share August 5, 2004 hmm how come? after every wash i have alot of excess water on the bonnet, roof n boot cover. so i thought to aid wiping the car dry, perhaps can use the wiper n remove all those water first before wiping dry those little bits. Link to post Share on other sites More sharing options...
Dwoon 1st Gear August 5, 2004 Share August 5, 2004 Errr..... you'll need to hold the squeegee flat to the surface, otherwise it won't work well. Then might as well just use the cloth to sweep away the collected water. Only possible efficient area I can think of is the roof where the surface is wide, quite flat and hard to reach the entire surface w/o going over to the other side. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 5, 2004 Share August 5, 2004 If the colour of your ride is dark colour. My advise is... dun use the wiper blade to wipe away the water. You'll end up having fine scratches... Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 5, 2004 Share August 5, 2004 go for spin dry ie. drive around for 5 mins at high speed. confirm all excess water will be gone! if lucky, dont even have to wipe dry thereafter Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie August 5, 2004 Share August 5, 2004 hi all, just wondering if it is safe to use used wiper blades (which u have replaced with new ones) to wipe away the excess water after a car wash? will it scratch the paintwork? thanks. please DO NOT use wiper blade or squeegee for drying purposes, they are not meant for car paint . If you want , you can try Autoglym Hydra Flexi Blade ( http://www.speeding.co.uk/acatalog/Product...Blade_154.html) , but I have since stopped using mine as I suspect one of the tiny scratches came from the blade when it caught dirt. I would strongly recommend getting a good waffle weave microfiber towel, it's excellent in drying. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 6, 2004 Author Share August 6, 2004 haha siao. lidat every time wash car have to waste petrol also. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 6, 2004 Author Share August 6, 2004 hmm okok then i betta not use lah. thanks all. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 6, 2004 Author Share August 6, 2004 what is squeegee? Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie August 6, 2004 Share August 6, 2004 squeegee is a tool with a rubber blade, the one that they use to clean windows eg in hotel, restaurants etc. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie August 7, 2004 Author Share August 7, 2004 o that one. ok thanks Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 9, 2004 Share August 9, 2004 Link to post Share on other sites More sharing options...
Tkew 1st Gear August 30, 2004 Share August 30, 2004 SteelBlue, 2 questions: 1. Does Autoglym Hydra Flexi Blade really work, and is it safe on the paintwork, i.e. any experience with scratch. 2. What's a waffle weave microfiber towel? Is it really absorbent, and where can I get it? Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie August 31, 2004 Share August 31, 2004 1.Yes it does work,but not so great on curvy surface, best on flat surface like the hood. I don't use it on the paint anymore as I got scratches due to dirt on the tip of the blade, so I leave the HFBlade for windows and windscreen. Do I recommend you getting it? No. 2.waffle weave mf is an micorfibre towel woven with waffle sort of pattern on it. The reason I like it a lot is it's very thirsty and soak up very quickly leaving no streak, hence no waterspots. Another thing is wwmf "gives you a little "margin of error"! Not only does it dry, but it is soft enough to cushion against any particles of dirt/dust that may still be on the vehicle. It can pull some of that stuff up into the towel, and prevent marring/spider webs of the surface"(quote from another forum). I bought my mf starter kits from here http://www.poorboysworld.com/microfiber.htm, those are really quality mfs and wwmf is included in the kit. Link to post Share on other sites More sharing options...
Jagash Neutral Newbie August 31, 2004 Share August 31, 2004 Yup, I am using the waffle weave MF cloth for drying and can dry the whole car without having to wring out the cloth at all! Very dry and safe and saves a lot of time. Link to post Share on other sites More sharing options...
Steelblue Neutral Newbie August 31, 2004 Share August 31, 2004 true true Link to post Share on other sites More sharing options...
Tkew 1st Gear August 31, 2004 Share August 31, 2004 Jagash, Where did you get your waffle weave mf cloth? SteelBlue's bought his from US based webstore, not worth the money in shipment. Any where to get it in Singapore? ↡ Advertisement Link to post Share on other sites More sharing options...
Looking for laptop
Looking for laptop
This car die die cannot buy pre-owned unit...
Donation of used clothing and toys
Used Car, what STA Inspection grade then can buy?
Get a new car plate number for used car
