Smallgasghost Neutral Newbie March 8, 2002 Share March 8, 2002 Hi, My wheels makes squeaking sounds in the morning... but after driving for the while the sound disappears... but will come back again if car is parked for a couple of hours... The front is disc and i can see the pads still have some life... back is drums... cant see sxxt... ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie March 8, 2002 Share March 8, 2002 How's the condition of the suspension system? Sometimes a spray of WD-40 to the source may do the trick, if the squeaking part is not due to damage. Link to post Share on other sites More sharing options...
Smallgasghost Neutral Newbie March 8, 2002 Author Share March 8, 2002 Ooops... forgot to mention that it squeaks when i brake. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie March 8, 2002 Share March 8, 2002 Did you recently changed pads? I recently changed mine and there's occasional squeaking too, nothing wrong with that. Also look for uneven wear on the disc, may be warped and if that's the case, needs skimming. Link to post Share on other sites More sharing options...
Smallgasghost Neutral Newbie March 8, 2002 Author Share March 8, 2002 Did you recently changed pads? Hahaha... that one never fail to crack me up... The front disc pads were change couple of months ago... the back drums were never touched... I think the squeaking brake sound is more from the back... and it only sounds when initial drive off... after a while no more sound. Link to post Share on other sites More sharing options...
Sky8807 1st Gear March 8, 2002 Share March 8, 2002 For the front brake pads, Cleaning and smoothing the pads to even it out may solve the problem if it is not too worn near to limits otherwise if the pads are nearing the wear limits sound will appear for some pads. For the rear, need to check the brake piston to see whether it is jammed if not cleaning the drum will do. Link to post Share on other sites More sharing options...
Ek69 Neutral Newbie March 8, 2002 Share March 8, 2002 I've the same problem months back. A mechanic told me to change back to original brake pads for my honda and it works for both front (disc) and back(drum). No more sound since then.....give it a try......... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie March 9, 2002 Share March 9, 2002 If you're sure the sound's from the back drums, you may have no choice but to take it for inspection. So new pads for you too huh? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 9, 2002 Share March 9, 2002 Probably need to clean the brake dust out of the drums. They accumulate and start causing noise when braking or moving off. Get a mech to air blast the dust out for you. ↡ Advertisement Link to post Share on other sites More sharing options...
Is Singapore Safe From Earthquakes ?
Favourite Japanese Songs from 1980-90s
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Yusheng from Singapore, Malaysia or China
