Andrewkb Neutral Newbie August 31, 2004 Share August 31, 2004 I noticed that most (if not all cars) has different height at all 4 corners of the car ... After some email exchanges with the coilover engineer, they mentioned that there is this thing called "Corner Balancing" ! Does anyone do this before ? Or just leave the 4 corners as it is ? If you're free, take a tape and measure all 4 wheelarch to the floor/mid of rims and U'll be surprised ! ↡ Advertisement Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie August 31, 2004 Share August 31, 2004 Agree with your observations. Perhaps all the 4 corners have unevenly distributed weight, from the components. (eg location of alternator, engine, cabling etc etc) also I think not all dampers and springs react uniformally against a certain weight. I seen some cars which appear lopsided on a seemingly even surfaced roads. For me, I'd leave it as it is.. unless of course if the variation is way too obvious. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 31, 2004 Author Share August 31, 2004 (edited) Because I'm using coilovers and I am adjusting myself, so got worried .. In conclusion, don't worry was what I was told .. For street car, today you might have 3 passengers, tomorrow 2, next day 5 ... so that changes too. For track use, they actually get the driver to sit in the car, weight all 4 corners, and adjust accordingly ! See this attachment .. it's a corner balancing sheet ... even with pro equipment, the after adjustment results are still not perfect. Apparently, it's for right hand drive car, since the right side is higher than the left. Edited August 31, 2004 by Andrewkb Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 31, 2004 Share August 31, 2004 not suitable for street use cars...unless yours is purely used for track or most of the time only you driving it then it is worth doing the corner balancing.... if you want to know just the weight at each corners, you can go to Leong Seng to do it.... Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 31, 2004 Share August 31, 2004 so troublesome one, that's why i didn't go for coilovers Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 31, 2004 Author Share August 31, 2004 Oh .. yah hor .. Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 31, 2004 Share August 31, 2004 springs & shocks combi less leychey Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 31, 2004 Author Share August 31, 2004 Aiyah .. change lah ... dun need to give excuse Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 31, 2004 Share August 31, 2004 may go for the eibach pro-kit springs, anyway the stock setup wasn't too bad on PG tracking session last sunday here's what happens to my tyres http://www.mycarforum.com/forum/gforum.cgi...t=629888#629888 Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 1, 2004 Author Share September 1, 2004 Yah saw it !!! Wouldn't have to heart to treat my tyre like this ! Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 1, 2004 Share September 1, 2004 it's stock tyres which is not up to my requirements wanted to trade in after collecting my car but not much $$$ comes back, so decided to use for almost a year then go PG to trash it out, so can change to a better tyre Link to post Share on other sites More sharing options...
Wrxblue 1st Gear September 1, 2004 Share September 1, 2004 (edited) hahaa.. yea..now really believe the legendary handling powess of the focus!!!!! although no power in the straights but when a corner comes.... thats where it shines!!!! and cant believe its stock standard setup!!!!! guess its the handling powess of the car that wear off your tyres!!!! too much G-forces!!!! Edited September 1, 2004 by Wrxblue Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 1, 2004 Share September 1, 2004 hahaa.. yea..now really believe the legendary handling powess of the focus!!!!! although no power in the straights but when a corner comes.... thats where it shines!!!! and cant believe its stock standard setup!!!!! guess its the handling powess of the car that wear off your tyres!!!! too much G-forces!!!! handling is really for a stock setup Link to post Share on other sites More sharing options...
Wrxblue 1st Gear September 1, 2004 Share September 1, 2004 hahaa..now you can imagine how good it will become when you install the 'kit' hahaaa ask Raycsk.... Link to post Share on other sites More sharing options...
Vtim 3rd Gear September 1, 2004 Share September 1, 2004 I know, so waiting for 2nd hand ones ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
Leave no dark corner
Creepy corner
Creepy corner
Fun corners
Fun corners
After Tyre Change: Balancing/Rotation or Alignment or Both?
Tyre installation service & charges only
CSCBB's coaching corner
Balancing Or Wheel Allignment
