Virus 2nd Gear September 17, 2004 Share September 17, 2004 [reply] I see, so the de-mister is for clearing fogging on the inside? or outside, confuse Actually both way, when you switch on during raining, you'll see the rain drop will just slip thru rear-screen. ↡ Advertisement Link to post Share on other sites More sharing options...
Kardachia Neutral Newbie September 17, 2004 Author Share September 17, 2004 u guys never got into a situation like this? Link to post Share on other sites More sharing options...
Tien Neutral Newbie September 17, 2004 Share September 17, 2004 de-mister is to warm up the glass and get rid of mist formed OUTSIDE. if mist is inside, just open the window for a while or on aircon to lower cabin temperature. Link to post Share on other sites More sharing options...
Kardachia Neutral Newbie September 17, 2004 Author Share September 17, 2004 This warming up is done thru wired-rear windscreen, am I right?, but front windscreen leh? just blow air only isit? Link to post Share on other sites More sharing options...
Tien Neutral Newbie September 17, 2004 Share September 17, 2004 yes. if you look at the base of your front windscreen, you will see air vents. those are there so that you can demist the front. but of course, need to turn your aircon to "warm" inorder to get warm air flowing lah actually best way to avoid mist is to off aircon and open windows. this way, both inside and outside temp. is the same and windows wont fog. can save fuel too Link to post Share on other sites More sharing options...
Kardachia Neutral Newbie September 17, 2004 Author Share September 17, 2004 I did that on the driver side windows, it didn' thelp....maybe next time I open all windows.... Link to post Share on other sites More sharing options...
Tien Neutral Newbie September 17, 2004 Share September 17, 2004 open one side only and outside air wont exactly flow into the cabin... try opening both sides, 1 side open wider, 1 side smaller. best down all 4 to the max ! ↡ Advertisement Link to post Share on other sites More sharing options...
how to remove micro/fine scratches on windscreen
How to remove stubborn stain on windscreen?
Best water repellent
Windscreen crack
Windscreen crack
Water marks removal on the windscreen glasses.
Suzuki windscreen sunshade
