Bluesbro Neutral Newbie August 8, 2005 Share August 8, 2005 Dun think thats a very good heat shield bro ... shld get a better one properly done ... heat most likely would penetrate from the bottom ... ↡ Advertisement Link to post Share on other sites More sharing options...
Accordvtec 1st Gear August 8, 2005 Share August 8, 2005 bottom is covered liao....the ass covered. Link to post Share on other sites More sharing options...
Kilomatrix 1st Gear August 9, 2005 Share August 9, 2005 (edited) Correct me if I'm wrong, to make sure that no heat is sipped through the heatshield, does that also mean that airflow would be impeded? The whole area around the air filter is enclosed, how then can it give u an effective air intake? It seems very little breathing space is going to be available for the filter, especially when the bonnet is closed. Will it affect performance at high rev? Edited August 9, 2005 by Kilomatrix Link to post Share on other sites More sharing options...
Accordvtec 1st Gear August 9, 2005 Share August 9, 2005 i channel air into the heatshield area via a flexible piping duct Link to post Share on other sites More sharing options...
Lorrliew Neutral Newbie August 9, 2005 Share August 9, 2005 I'm new in this open pod thingy! Like that would it be almost similar to CAI liao? Link to post Share on other sites More sharing options...
Imuya Clutched August 9, 2005 Share August 9, 2005 hey hey! you thinking along the same lines as i did and came to the same conclusion! that's why DIYing your own CAI and air intake system is so fun!! Link to post Share on other sites More sharing options...
Accordvtec 1st Gear August 9, 2005 Share August 9, 2005 yes,bro....would you like to install? Link to post Share on other sites More sharing options...
Lorrliew Neutral Newbie August 10, 2005 Share August 10, 2005 My car comes with original CAI through stock filter box, using K & N drop in filter. Any good recomendation for futher improvement? Link to post Share on other sites More sharing options...
Kilomatrix 1st Gear August 10, 2005 Share August 10, 2005 bro, care to share where u bought the insulating foam? Link to post Share on other sites More sharing options...
Accordvtec 1st Gear August 11, 2005 Share August 11, 2005 open pod filter with heat shield best..... Link to post Share on other sites More sharing options...
Accordvtec 1st Gear August 11, 2005 Share August 11, 2005 my workshop is doing this. Auto dynamac. Blk 3019A Ubi Rd 1 #01-28 tel:67459702 Look for Raymond.He will advise you Link to post Share on other sites More sharing options...
Seanboi 1st Gear January 16, 2006 Share January 16, 2006 Bro just the HS alone how much? Link to post Share on other sites More sharing options...
Accordvtec 1st Gear January 16, 2006 Share January 16, 2006 around $150..pls call and check with Raymond.He does a good job for the heat shield Link to post Share on other sites More sharing options...
Sujoy Neutral Newbie January 19, 2006 Share January 19, 2006 Is there any model of the normal A'PEXi air filter for KIA Cerato? ↡ Advertisement Link to post Share on other sites More sharing options...
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
Microsoft to buy solar power in Singapore
Cordless power tool system - which one ?
Not all heroes wear capes! Liverpool taxi driver prevents terrorist attack!
My built-in oven trip the house power supply
