Turbobrick Neutral Newbie January 2, 2002 Share January 2, 2002 You need to find out where the leak is. Common leak points are: the steering rack, check around the rubber boots on both side. Check where the lines connect into the rack, and the line that screws into the power steering pump, sometimes the green "O" ring on that connector could be pinched. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Steering column
Steering column
Renal failure on the rise
Trunk Rack for Bicycle
Is FN2 is really a failure?
