Mondeo Neutral Newbie November 13, 2002 Share November 13, 2002 "Once spent, No regrets" That's life ↡ Advertisement Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 13, 2002 Share November 13, 2002 As long as I'm happy! Money can always be earned back. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie November 13, 2002 Share November 13, 2002 Yes! sometimes when u get the money, u've missed the happy. Link to post Share on other sites More sharing options...
Blue Neutral Newbie November 13, 2002 Share November 13, 2002 Hi Blue, I think the problem with the GTti was that the oil filler cap was not the screw on type. It was more like a insert. A change of the O-ring could solve the problem, i guess. Hi Lordgt Guess you're right, but would'nt be able to try it out now .............. but what then caused the connecting hoses from the snail to the intercooler and also the intercooler to throttle body to pop out? .............................anyway it's history now. Thanks for the enlightenment abt the coolers , maybe can look for those pajero's or troopers coolers - cheaper way out mah Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 13, 2002 Share November 13, 2002 hahah what i meant was second hand. Well oil coolers does keeps water temp down. ATF will give your tranny an extended life span. Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 13, 2002 Share November 13, 2002 So are you always happy or not happy? hahhahah Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 13, 2002 Share November 13, 2002 well pressure is one thing i can think of, another could be loose fittings. Trooper and Pajero was used as an example, it could or might not fit. I'd rather get a brand new one, for that kinda price. eg. $150 second hand, $280 brand new. ATF coolers aren't that expensive or are you talking about Engine Oil coolers? Link to post Share on other sites More sharing options...
Blue Neutral Newbie November 13, 2002 Share November 13, 2002 Well actually i had the e-oil coolers in mind and since that the atf coolers extends the life of the tranny, i am thinking of installing both. That is if space permits and the price is right Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 13, 2002 Share November 13, 2002 oic. Well those trucks/cars/jeeps watever you call is usually are bloody huge. If you want a non-uniform look, can try the scrap yards. But be sure that its not the leaky ones. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 14, 2002 Share November 14, 2002 Can say I'm happy most of the time........... Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 14, 2002 Share November 14, 2002 hahaha ok lor. $$$$$ many many of cos happy la. hahah... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 14, 2002 Share November 14, 2002 In case you don't notice, money is always no enough..................... Correct? Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie November 14, 2002 Share November 14, 2002 well i don't know about you, i definately no enuff. but some is so filty rich, money take and throw. Link to post Share on other sites More sharing options...
Wymun Neutral Newbie November 16, 2002 Share November 16, 2002 Just a point of advice for cars with inbuilt ATF coolers; but like me, added an aftermarket one as well. Make sure the mechanic doesn't isolate the new aftermarket cooler from the inbuilt one. Rather he should extend the cooling from the existing setup onto the auxiliary ATF cooler, which then offers better cooling...;) If not, the after-market auxiliary cooler may not be as efficient as stock, simply because it may not be as big..... This doesn't apply to those cars that don't have a pre-existing ATF cooler... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 17, 2002 Share November 17, 2002 You mean connecting the two in series. Link to post Share on other sites More sharing options...
Wymun Neutral Newbie November 17, 2002 Share November 17, 2002 Heh...exactly... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie November 17, 2002 Share November 17, 2002 Why don't you invest on an oil cooler? Link to post Share on other sites More sharing options...
Wymun Neutral Newbie November 17, 2002 Share November 17, 2002 (edited) I wanted to install an engine oil cooler this weekend actually. Brought along all my engine oil. But, along the way, gave CS Racing and AutoFix a call - found out that no one was around to handle a new oil cooler order/installation. Hence, may have to wait another week... Still, I meant connecting the aftermarket ATF cooler to the inbuilt ATF cooler in series (as you described). Nothing to do with an engine oil cooler (if that's what you meant)... Edited November 17, 2002 by Wymun ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback on evaporative air coolers
Recommendation for ATF Cooler brand and Installer
Rubbermaid cooler box to give away
Where to buy this water pump for Air cooler?
Inter cooler and after cooler
Multiflow ATF Cooler
Hayden ATF Cooler
Hayden ATF Cooler
Can air cooler cool room to 25degrees?
