Sheltie2306 Neutral Newbie February 27, 2005 Share February 27, 2005 Hi, has anyone use this before? Particularly the "system 2d" that has a 3D water map. ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 28, 2005 Share February 28, 2005 Ah, finally interested in the aquamist liao 300++ still not enough har Link to post Share on other sites More sharing options...
Sheltie2306 Neutral Newbie February 28, 2005 Author Share February 28, 2005 no choice lah ... temperature here too hot Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 28, 2005 Share February 28, 2005 aiyah, sell your STI & buy a 3.2L V6 N.A. car lar Link to post Share on other sites More sharing options...
Sheltie2306 Neutral Newbie February 28, 2005 Author Share February 28, 2005 hahah ... the GTA ?? no lah .. i like turbo, the great feeling of turbo kick ass feeling !!! Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 1, 2005 Share March 1, 2005 GTA can go from 3.2 to 3.8 V6 hor! very very 'fun' to drive Link to post Share on other sites More sharing options...
Eugh Neutral Newbie March 2, 2005 Share March 2, 2005 Hi, has anyone use this before? Particularly the "system 2d" that has a 3D water map. Am also thinking of this - how much is the 2d system? I know that the 1s is already $1k+ Link to post Share on other sites More sharing options...
Sheltie2306 Neutral Newbie March 2, 2005 Author Share March 2, 2005 Its 1300 with installation Link to post Share on other sites More sharing options...
Eugh Neutral Newbie March 3, 2005 Share March 3, 2005 Thanks - is it from GMS? May be dropping by their place to see if can fit in my ride... Link to post Share on other sites More sharing options...
Sheltie2306 Neutral Newbie March 3, 2005 Author Share March 3, 2005 Yes, it's from GMS. However, with water injection itself, there's no power improvement. You need to take advantage of the water cooling effect, so that you can run higher boost, or more timing advance, or run more lean, in order to get more power. Link to post Share on other sites More sharing options...
Eugh Neutral Newbie March 3, 2005 Share March 3, 2005 Am more concerned with heat management rather than more power. Anyway, do not think that I can adjust any of the above as my car is running on an aftermarket chip which I understand is not externally tunable. Link to post Share on other sites More sharing options...
Sheltie2306 Neutral Newbie March 3, 2005 Author Share March 3, 2005 Don't think so, unless you have a programmable ecu. ↡ Advertisement Link to post Share on other sites More sharing options...
