Guyver 1st Gear March 28, 2002 Share March 28, 2002 Hi all, just would like to know any of u has changed your auto transmission oil before? Pls feedback, I heard from a fren of mine that it improves milage. According to what i know the standard ATF we have is not fully synthetic, is it true? ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear March 28, 2002 Author Share March 28, 2002 Anybody can tell me where is a cheap & good place to change my ATF?? Link to post Share on other sites More sharing options...
Yongwd 1st Gear March 28, 2002 Share March 28, 2002 done it at Sentosa JB around RM$120. Complete flush at RM$120 Anybody can tell me where is a cheap & good place to change my ATF?? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 28, 2002 Share March 28, 2002 With Mineral ATF right? How many litres they flushed out? Link to post Share on other sites More sharing options...
Yongwd 1st Gear March 29, 2002 Share March 29, 2002 Yes its Mobil mineral Dex, 11litres in total With Mineral ATF right? How many litres they flushed out? Link to post Share on other sites More sharing options...
Toyota22 Neutral Newbie March 31, 2002 Share March 31, 2002 Just send my car for servicing and the guy help to change my ATF which cost $6 per litres and my car soluna use 2.5 litres. The ATF is from ESSO. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 31, 2002 Share March 31, 2002 That's a fair price for mineral ATF, your Soluna holds quite little ATF in the sump Link to post Share on other sites More sharing options...
Yongwd 1st Gear March 31, 2002 Share March 31, 2002 Toyota recommend complete ATF change 80,000km (Soluna) and must be fully synthetic. ATF Filter to be changed at 160,000km. Just send my car for servicing and the guy help to change my ATF which cost $6 per litres and my car soluna use 2.5 litres. The ATF is from ESSO. Link to post Share on other sites More sharing options...
Toyota22 Neutral Newbie April 1, 2002 Share April 1, 2002 Toyota recommend complete ATF change 80,000km (Soluna) and must be fully synthetic. ATF Filter to be changed at 160,000km. Just send my car for servicing and the guy help to change my ATF which cost $6 per litres and my car soluna use 2.5 litres. The ATF is from ESSO. Not sure whether the ESSO ATF if synthetic a not ? Link to post Share on other sites More sharing options...
Guyver 1st Gear April 1, 2002 Author Share April 1, 2002 Yah, i'm now at 71,000km already.... so probably need to change my ATF in couple of months time.... Link to post Share on other sites More sharing options...
Guyver 1st Gear April 1, 2002 Author Share April 1, 2002 So cheap? don't think it's synthetic one..... i as my regular machanic.... he told me to change the ATF for my car cost about $60..... using shell..... ATF... Link to post Share on other sites More sharing options...
Toyota22 Neutral Newbie April 1, 2002 Share April 1, 2002 So cheap? don't think it's synthetic one..... i as my regular machanic.... he told me to change the ATF for my car cost about $60..... using shell..... ATF... I guess so . Then for non synthetic how often it need to be change ? Link to post Share on other sites More sharing options...
Yongwd 1st Gear April 1, 2002 Share April 1, 2002 mineral usually half the life of synthetic. See if your gearbox require DexII or III grade ATF. Mineral is about $6 per litre So cheap? don't think it's synthetic one..... i as my regular machanic.... he told me to change the ATF for my car cost about $60..... using shell..... ATF... I guess so . Then for non synthetic how often it need to be change ? Link to post Share on other sites More sharing options...
Scat_cyz Neutral Newbie April 5, 2002 Share April 5, 2002 You can try Ah Lin at Sin Ming. His place is at Blk29 Sin Ming Ind Estate #01-215 (O) 64563710. Quote Steven (Nissan VIP). Changing the ATF is easy, not sure if he has the flushing facility but flushing is not really necessary if your car is less than 10 years old. Nevertheless, Royal purple ATF is quite good. And ATF usually runs for 40,000 km before changing is required however you will still need to condition monitor its condition. Link to post Share on other sites More sharing options...
Guyver 1st Gear August 15, 2006 Author Share August 15, 2006 Toyota recommend complete ATF change 80,000km (Soluna) and must be fully synthetic. ATF Filter to be changed at 160,000km. Just send my car for servicing and the guy help to change my ATF which cost $6 per litres and my car soluna use 2.5 litres. The ATF is from ESSO. Revive old thread ... so for my G9 ... the transmission fluid should change about now lah .... as the mileage is almost 100,000km liao. Another thing, my G9 got no timing belt ... but somebody was telling me got another belt that needs to be replaced ..... got meh? Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear August 15, 2006 Share August 15, 2006 use ONLY Toyota Type T-IV for your G9 auto-trans. need only to drain and refill. don't need to flush. one 4 litre tin only cost $24-$26. using any other ATF may damage your AT. Link to post Share on other sites More sharing options...
Bryanho Neutral Newbie August 16, 2006 Share August 16, 2006 Another thing, my G9 got no timing belt ... but somebody was telling me got another belt that needs to be replaced ..... got meh? ============================================================================== Nine_Eleven is correct and to add on.. You have to change the alternator belt-long one and the alternator belt pulley.. these two, plus get the water pump! Total 3 items Worn out pulley below New Pulley below Compare the wear... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 16, 2006 Share August 16, 2006 Bro, with your mileage the following items should be changed 1) Fan Belt 2) Power Steering Belt 3) Water Pump Assembly 4) Water Pump Bearing 5) ATF (Flush) The rest of the fluid, please monitor yourself ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Changing halogen to LED
Reputable like Lye Design in Amk Auto-point
