Optus76 Neutral Newbie March 20, 2005 Share March 20, 2005 Hi Guys... Anyone had this problem...i suspect it's the Engine Temp... While idling for a long time or stuck in traffic jam i will hear this Click Click sound like as if someone is knocking my shaft with a spanner... Could this be the raising temperature causing metal to expand ? and making all those noises ...if i started moving fast the sound stops... Temp Gauge is normal tho... ↡ Advertisement Link to post Share on other sites More sharing options...
Stepper Neutral Newbie March 20, 2005 Share March 20, 2005 maybe it is just the thermostat that is working.. Link to post Share on other sites More sharing options...
Optus76 Neutral Newbie March 20, 2005 Author Share March 20, 2005 BUT DAMN LOUD ,....if ya know what i mean ..... Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 20, 2005 Share March 20, 2005 could it be from air con? Link to post Share on other sites More sharing options...
Ferrariz Neutral Newbie March 20, 2005 Share March 20, 2005 your engine might be knocking... better put some octance booster...or pump a higher octane fuel if you are already using a high octane fuel..then check your engine oil level, engine coolant level...etc ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
Engine Mounting
Engine Mounting
