Peterkoh Neutral Newbie December 18, 2002 Share December 18, 2002 Hi Folks, Thinking of bridging my 4 channel to 2 for my front. That means I need an active woofer or another amp. Can I just get the cables and splitters and tap the power/ground/on-off signal from the current points connected to the existing amp (4 channel Alpine V12) ? Anything I need to watch out for ? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Et2002 Neutral Newbie December 19, 2002 Share December 19, 2002 Hi 1) You need to make sure your power cable is thick enough for the 2 amps. 2) you will very likely need to change your existing fuse which is near the battery. (change to Higher fuse rating) Typically, you run the power cable with a dedicate main fuse not more that 1 ft from the battery and the power cable can run all the way to your trunk. And the trunk will need another distrubuter block with fuses.. You will than split from there with their individual fuse.... and than to the power terminal of the individual amps. If you wanna diy.. go to this website.... they will teach you to calculate power cable guages http://www.eatel.net/~amptech/elecdisc/caraudio.htm Go to the section on wires Hope these helps. ↡ Advertisement Link to post Share on other sites More sharing options...
Feels Like Insomnia
Feels Like Insomnia
Home repair advice needed
Computer advice needed
Advice on exhaust.
Advice on exhaust.
