Unknown_G7 Neutral Newbie May 20, 2005 Share May 20, 2005 My car had this problem for quite some times since being rear-ended. Whenever I start my car, the rpm was at 200 (that's very low) for few minutes before slowly up to around 400. After I drive for quite some distance, the rpm will then stay at normal 800. Is it due to faulty spark plug cable or dirty plugs? ↡ Advertisement Link to post Share on other sites More sharing options...
Steam Neutral Newbie May 20, 2005 Share May 20, 2005 ur g7? Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 yup the same g7 Link to post Share on other sites More sharing options...
Steam Neutral Newbie May 20, 2005 Share May 20, 2005 call me Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 20, 2005 Share May 20, 2005 Even @400rpm, most of the engine will cut out once you engage the gear. Are sure the engine speed is correct. Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 20, 2005 Share May 20, 2005 I assume 400 rpm is the idling rpm. If he's driving a manual car, can tap the accelerator slightly to bring the rpm a bit higher before engaging the gear. That way the engine won't die off. Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 20, 2005 Share May 20, 2005 My car had this problem for quite some times since being rear-ended. Whenever I start my car, the rpm was at 200 (that's very low) for few minutes before slowly up to around 400. After I drive for quite some distance, the rpm will then stay at normal 800. Is it due to faulty spark plug cable or dirty plugs? Does your car have auto-choke? Example previously, when you first start the engine, rpm will be slightly higher initially (maybe 1500 rpm ~ 2000 rpm), and then drop to around 800 rpm ~ 1000 rpm after a while? Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 Just reach home from work. Will call you on sunday Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 Have to rev a bit higher at between 1k - 1.6k to change gear. If normal rev to above 2k, the engine will roar. Last time, my car hit 90km at 2.5k rpm. Now 90km at between 1.6k - 1.8k rpm. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 seems like ur idling a bit low...perhaps u wanna adjust to abt 1k idling. if too high, waste petrol. do check ur auto/manual choke...too, may be faulty. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 I don't think my car have auto choke. Previously when I start my car, the rpm will be at around 800 for few minutes before maintain at 1k. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 mine dun have any idling prob when use mineral. when i switch to syn oil, need to step accel before start car...anyone kw why..heard starting need more petrol + air - hence the additional pump of accel. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 yup very low, the whole car are vibrating. I thought only motorcycle then got choke Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 mine used to be below 1k idling..wah car vibrate like craze....now no more such symptoms after adjust 1k idling. cars do come with auto or manual choke...but not sure iszit all cars. Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 I tried tapping on the accelerator pedal before starting the car. It work as the rpm was like normal 800. But when I drive off, the rpm drop again to miserable low Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 20, 2005 Author Share May 20, 2005 Btw where's the auto/manual choke normally located at? Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 try on a/c...the choke shd cut in...hence maintain the rpm Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 20, 2005 Share May 20, 2005 shd be at just the outside of the cabruettor. size of golf ball. mine located near windscreen direction. ↡ Advertisement Link to post Share on other sites More sharing options...
To be Happy, start thinking about Death!
Feedback
Feedback
The 2017 Alfa Romeo Giulia
Budget 2025 - February 2025.
Dealer re-sell problem car
