Carlover76 Neutral Newbie December 24, 2002 Share December 24, 2002 Just like to check with you with the change of the default air filter to the cone type, will it affect the engine in the long run? I heard some people telling me that the engine will get dirty because of the cone shape air filter as it allows more air to go into the engine, is that true? So anyway to clear the dirts inside the engine? Anyone care to enlighten me, thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 24, 2002 Share December 24, 2002 Just make sure you don't place the filter where hot air will be suck in as this will give worse performance..... Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie December 24, 2002 Author Share December 24, 2002 My air filter is placed just behind of the battery where cold air is but then does the engine gets dirty by placing there? How to clear those dirts from the engine, any idea? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 24, 2002 Share December 24, 2002 (edited) The Battery will get hot and if suay suay the acid spill out and get into the filter....bad news..... Make a shield for your air filter to be safe... Edited December 24, 2002 by Eddie Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie December 24, 2002 Author Share December 24, 2002 But according to what the agent say, the battery is maintenance free cos it is a dry cell battery unlike those old cars using the acid battery so I guess I do not need to make a shield for that right? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 24, 2002 Share December 24, 2002 Even so, Shield is still a must as battery do get hot when it is charging.... Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie December 24, 2002 Author Share December 24, 2002 Ok, care to teach me to do a shield, you can contact me at 98248801, thanks! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie December 24, 2002 Share December 24, 2002 Use Aluminium sheet to create box-like enclosure to shield the air filter from the battery....secure by bolt and nut or cable tie to any anchoring point. If you could show me a digital picture of your engine bay, I might be able to give you better instruction on how to construct one. Link to post Share on other sites More sharing options...
Liang Neutral Newbie December 25, 2002 Share December 25, 2002 My Zafira's bty is covered by a thin plastic sheet with some foam (feels like foam, spongy feeling) inside. I think most modern engines have this feature. Just hope that it doesn't mean the bty burn out faster! ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
MOM help FTs look for jobs ?
